Old 06-28-2017, 02:27 PM
lemix's Avatar
lemix lemix is offline
Default Question re : Co Install
Hello friends,
First..can I have two versions [ 12.4 & 12.8 ] installed on my W7 DAW ?
Spex in sig
If so, could you please guide me through the steps from downloading > iLok things> preferences..etc, please.
Yes, I should know all that but have been away for a very long time.
thanx many !
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 06-28-2017, 02:30 PM
john1192 john1192 is offline
Default Re: Question re : Co Install
Originally Posted by lemix View Post
Hello friends,
Spex in sig
thanx many !
if i am correct .. you can only have multiple installs of Pro Tools on a MAC ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-28-2017, 02:43 PM
Drew Mazurek's Avatar
You are correct John. You can only co install on the
www.drewmazurek.com
Old 06-28-2017, 03:17 PM
YYR123's Avatar
YYR123 YYR123 is offline
Yep only co-Install that is possible is Win7 and only with PT10 as the secondary Install
On Windows 7, Pro Tools 10.3.10 can be co-installed on the same system with Pro Tools 12.x. (Windows 7 Only)
If you have an earlier version of Pro Tools installed, it is recommended that you perform a clean uninstall before installing Pro Tools 10.3.10 (or higher) and Pro Tools 12.0 (or higher). Installing Pro Tools 12.x will overwrite Pro Tools 11.x if it is already installed.
Uninstalling Pro Tools does not uninstall all components that are installed
From the readme
Daniel
Old 06-28-2017, 05:17 PM
Carl Kolchak Carl Kolchak is offline
I have a feeling you can co- install PT10, and PT12 on Windows 10, provided you install PT10 first.
Old 06-29-2017, 07:35 AM
lemix's Avatar
Thanx All
Bummer though, as my 12.4 version is more than I would ever need from PT Vanilla. But..did have a couple of video related glitches. And...I have this 12.8 sitting there under my current subscription.
Would I have to completely uninstall everything Avid before attempting to get 12.8 on my system ? ?
I also find that super annoying..
I have 3 different versions of Nuendo running without a hitch...just saying.
Again, I appreciate your input .
Ohh and BTW, just reading about some iLok issues. What should I check for in order to avoid pulling my hair out ? My Pace software is fully up to date and have Avid perpetual 10-11-12 showing. Will there be a separate 12.8 license deposited by Avid....automatically ???
Why does this whole exercise look so bloody complicated
cheers,
Andrew
Old 06-29-2017, 08:54 AM
You can make separate partitions. And with SSDs reboots should take 20 seconds
www.drewmazurek.com
Old 06-29-2017, 09:54 AM
Or clone your system drive, swap it out and put the other version of PT on the clone
Old 06-29-2017, 11:07 AM
YYR123's Avatar
Off topic Albee what cloning software do you use?
I've been using Macrium and it's easy but I'm having problems cloning more than one OS drive to my HDD. (A Terabyte multi partitioned)
On this subject MAC was super easy, CCC was a 1 button kind of thing
Daniel
Old 06-29-2017, 12:05 PM
Originally Posted by YYR123 View Post
Off topic Albee what closing software do you use?
I had a weird issue with Reflect and went with Backupper Pro. There is a free version of Backupper(worth a try), but the "pro" version has a function specific to cloning the system drive and its worked really nicely for me Acronis worked okay, but I seemed to have to chase down BIOS settings to get it booting from the correct drive after a swap.
Install question Cal D macOS 3 01-19-2016 10:49 PM
PT 9 MC 6.5 co-install question m.palius Windows 0 09-12-2012 07:27 AM
Newb install question: Install seems to complete and than freezes ginsuthaironchef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-02-2009 03:39 PM
install le 7 question help? amore125 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-20-2008 11:04 AM
DFH install question qas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-29-2004 05:02 AM
