Old 04-16-2018, 12:10 AM
jaydenseeley jaydenseeley is offline
Default Routing system audio in as a channel input?
Bit of a weird one - Is there a way to set the input of an audio channel in Pro Tools to record the system audio of my computer?
I'm outta ideas and would love to hear yours.
Thanks!
Old 04-16-2018, 01:08 AM
Default Re: Routing system audio in as a channel input?
Take the output of your computer, preferably digital, and connect it to inputs on your interface.
There are software solutions as well, but good old hardware works reliably.
You will get better help if you describe your setup and what you are trying to do.... record what computer audio for what purpose etc.
Old 04-16-2018, 01:22 AM
Thanks for the response! I'm running without an interface at the moment so am looking for a software solution.
Basically I have a third-party synth app that isn't compatible with Pro Tools. My idea for a solution would be to simply record the system audio live in Pro Tools while I'm playing on the app.
I've attached my basic setup!
2012 Macbook Pro
2.5 GHz Intel Core i5
16GB DDR3
Mac OS High Sierra
Pro Tools 12
Korg microKEY 25
Old 04-16-2018, 05:02 AM
2012 Macbook Pro
16GB DDR3
Mac OS High Sierra
Pro Tools 12
Korg microKEY 25
Not compatible with PT? Do you have an au or vst version of the plugin? If so grab BlueCat Patchwork or MB7 to host the plugin. Use Patchwork as a track insert and put the synth plugin inside Patchwork. What synth are you talking about and are you sure there's no aax64 version? And is the synth 64 bit?
There are easier ways to accomplish what you want without a Rube Goldberg kludge.
Jack
QAPLA!
Old 04-16-2018, 05:55 AM
Sardi Sardi is offline
What you want is Source Nexus.
https://source-elements.com/products/source-nexus
Old 04-16-2018, 08:09 AM
You're talking about the free version right?
Jack
QAPLA!
Old 04-16-2018, 11:35 AM
There is also loopback and other apps, but as pointed out already I would start with trying to run the synth inside Pro Tools.
Old 04-16-2018, 04:34 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Thanks!
https://rogueamoeba.com
IMDB
Old 04-16-2018, 05:05 PM
mattrixx mattrixx is offline
Another option is to use SoundFlower as part of an Aggregate device. Works a treat.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
HELP: Routing MacPro system audio through Avid interface... Darryl Duncan Pro Tools 12 2 10-23-2016 11:48 AM
32 Channel Input / 16 Channel Output Device(s)? tcstx Pro Tools 9 33 02-07-2011 03:04 PM
Routing Aux Mix to Channel wmmccoy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-17-2005 07:55 PM
Routing input 5 from 002 to input 1 Amplitube Live stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-27-2004 12:56 AM
Mbox - Routing the computers audio through the mbox ie. CD Rom, system sounds brownmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-30-2003 03:22 PM
