Old 12-02-2017, 04:49 AM
oplatner oplatner is offline
Default 11R isn't recognized in pro tools 10 - help needed
Hey guys,
I'm writing this as I need help, all the search I've done didn't help...
I just formatted my PC and installed Windows 10 home edition.
I followed all the usual instructions, installed the lastest 11R drivers and the latest Pro Tools 10 installer, but every time I try to launch Pro Tools I get the already known error:
"unable to locate hardware. make sure your hardware is connected".
My 11R is configured correctly, no issues in windows device manager, I can listen to music by using it and the 11R stand-alone editor works perfectly fine!
I also checked for issues with my Ilok, there are none (license is activated). I also tried installing ASIO4ALL and Pro Tools launched correctly, but in the device setup menu the only thing that appeared is ASIO4ALL, the 11R isn't there...
I can't understand why my 11R works perfectly but it just isn't recognized by Pro Tools.
How can you guys help me here? What else should I do in this case?
My YouTube channel: http://www.youtube.com/user/oplatner79/videos
Old 12-02-2017, 01:05 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: 11R isn't recognized in pro tools 10 - help needed
Is the Eleven Rack set as your Windows Audio Interface? If so, try disabling it from Windows.
Uninstall the driver and clear everything out like in this video
Trash Pro Tools preferences.
Then reinstall the driver.
If that doesn't work, uninstall the driver again, clear everything out, and try an older driver since you are on Pro Tools 10 and not 12.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 12-02-2017, 01:27 PM
disabling it on windows means I can't use it as a standard sound card? (will not be able to listen to music)
Old 12-02-2017, 01:36 PM
Disabling it on Windows is what you should be doing of you want to use it with your DAW. You can enable it later to work on Windows if you want.
Even if the driver appears to work OK with multi-client applications, it's bad practice on Windows to do this.
But either way, you are having problems, just try it....
And please follow the DUC guidelines and don't start multiple threads for the same problem.
Old 12-03-2017, 03:53 AM
Seemöwe Seemöwe is offline
Like Benoni wrote, try older 11R drivers. I use also Win10 + Pro Tools 10 and driver v. 1.1.10 is the latest version works for me.
Old 12-03-2017, 10:40 AM
I did exactly as you said, downgraded to v. 1.1.10 driver and now everything works perfectly!!!
Thanks' man! you saved me!
Old 12-03-2017, 12:12 PM
Great!
HDD Not recognized by Pro Tools DamDro Pro Tools 10 3 09-23-2015 11:08 AM
Pro Tools 903 Update not recognized Awesomealex9 macOS 5 06-21-2012 12:03 PM
Midi not recognized by pro tools! jaimarec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-08-2011 08:12 PM
FWx on SC48 not recognized by Pro Tools LE Robert I VENUE Live Sound Systems 4 10-01-2010 12:55 PM
xboard is not recognized in pro tools 2hip2b4real 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-13-2009 09:18 AM
