Trim mode disagreement
Sometimes the Trim Light on the dock and the trim status of the focused track in Pro Tools disagree. I cannot find a consistent set of steps to reproduce...
also I can't tell if it's the actual trim modes disagreeing between PT and Eucon... or just the light not working... Happening for anyone else?
IMDB |
Re: Trim mode disagreement
What do you have this setting set to: Dock Automation Mode Buttons Follow Attention Track
It is on, and functions as it should... I'd say 97% of the time... just occasionally disagrees. I press 3 times and they get back in sync. I'm going to pay more attention next time to see if I can get a more solid diagnosis for you.
IMDB |
... Still can't reproduce reliably...
but more info. - The indicator on the track in protools, and the trim mode light on Eucon agree that trim mode is off. - The track functions like trim mode is off. - The yellow "trim line" on the volume automation track is showing. Which it should NOT be. If I toggle trim mode on/off on either the track or the control surface the yellow line goes away and it functions normally. So might not be a Eucon issue at all... could be a "yellow trim line" issue.
IMDB |
What version of PT is this ?
I think you must have Coalese Trim turned off? You are seeing that theres still a Trim value thats not merged.
Perhaps I'm misunderstanding, but I'm not sure there's a problem here; It's perfectly possible to display trim automation even if the fader is not in trim - just toggling through display modes (ctl-cmd-left/right arrow) will show you the trim line regardless of automation status.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 Last edited by Rich Breen; 08-07-2020 at 03:36 PM. |
Ah. good thought, but my explanation wasn't super clear.
It's not the volume trim view... this is still in the volume automation view... shows the straight yellow line as if in trim..., but isn't really (recreation attached)
IMDB |
S1 trim mode | Norad155 | Avid S1, S3, Dock and Control App | 14 | 09-23-2020 09:26 PM |
Is there a preference that when in Trim mode, trim doesn't apply to sends? | bassmagnetic | Post - Surround - Video | 2 | 12-19-2019 07:55 AM |
S3 bug: track exits trim mode after writing send automation in preview mode | yoerik roevens | Avid S1, S3, Dock and Control App | 4 | 06-27-2017 10:38 PM |
Where did the Trim Mode go in PT 10? | Imbie | Pro Tools 10 | 1 | 09-19-2012 09:56 AM |
trim mode on sends? | tomlowd | ICON & C|24 | 3 | 06-26-2007 07:38 PM |
