Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 06-04-2020, 10:18 PM
hugolamb7 hugolamb7 is offline
Default Unable to download project from cloud
Hello
I have spent several hours working on a project on Pro Tools First, saving the session onto the cloud (I have 99gb of available space). I saved and closed my work last night, and now when I try to open the project I get the message "Unable to download project". It then prompts me if I want to try and open it from the cached files. When I click ok, I then get the message Could not complete your request because The parameter is incorrect. (87) c:\Users\name\Documents\Pro Tools\Project Cache\ARmPnxh8bHwVEsiRN-tQAd\yxAtUmHVjjPSAAC4G6WVcd.ptproject\Revision History\Manual Saves\0018.ptpx.
I have tried uninstalling and re-installing all the hardware and plug-ins, including for the cloud server client. I have also tried running as administrator. I have tried creating a new session and importing the tracks, but all the audio tracks that were in the project appear as 0 bytes and cannot be imported.
Pro Tools First version 19.6
OS Windows 10 Home
RAM 8gb (7.9 usable)
Processor Intel, 2GHz, 64-bit OS
Any advice would be appreciated.
Old 06-25-2020, 03:55 AM
BenAvison BenAvison is offline
Default Re: Unable to download project from cloud
Hi - Did you get a response? I have similar issues - my files disappeared from the local cache in PTF 2019.6 and will not download from cloud (says "0% downloaded")
Old 06-25-2020, 11:04 AM
junkgear's Avatar
junkgear junkgear is offline
Not sure how to get back your project files, but in the future you will want to make sure that your projects fully synced to the cloud.
It is recommended, and I would highly suggest that before closing your project that you open and monitor the PT Task Manager. You open it from the Window menu:
Window->Task Manager
Once there are no more running tasks, then you are safe to exit PT.
Just to test that everything is working properly, I would create a new project with the Backup to Cloud selection checked. Record just a few small tracks, then open the Task Manager, save the project and close the project. You should see a few tasks run stating that it is backing up to the cloud. Once finished, close PT altogether.
Restart PT and see if you can open the new project.
Will
System Details
Cannot open Cloud project Peters86 Pro Tools 2020 2 05-07-2020 08:34 AM
Protools First Cloud project headlap Pro Tools 12 2 12-11-2018 12:03 PM
Incomplete project upload/download to cloud? ajinoz Pro Tools | Intro Discussion 1 08-25-2018 07:59 PM
Always 99% cloud even an empty project ... babaorum Pro Tools 2018 17 07-19-2016 09:18 AM
