Weird Playback record issue
So I have a problem whenever I record a project at one studio on a diffrent TDM or DIGI 001 system, I get a flaw that their systems have as well in those projects and only those. So I will be recording at their studio and if I hit Record first it take FORECVER before it starts up and actually starts playing and recording. Where as if I just hit Play and then use Quick Punch to just get right into recording a milisecond later it starts up just fine. My home system never does this unless I start the project on their systems. So meaning if I start the session at home I dont have this problem. How do I solve this??????
Jesse Cannon |
Re: Weird Playback record issue
next thing is in the prefrances of PT, i cant remmeber what tab its under and i will post once i get back to my studio which should be monday, you will wanna change a preferance and limmit the recording time say....15 minutes. instede of unlimmited or the 60 min setting. agian it all depends on the system you have. if its HD, and you have a large session say 7 gb or more... it will take a long time to search the drives and stuff. what kinda HD do you run firewire? Sorry for the miss spellings i was rushin
Kevin Lucero Illustrated Sound Studio |
Besides the open-ended allocation in the prefs... also check that DAE buffer (in the DAE app) is set to 2, and that the countoff in record (it's toggled with the 8 key) isn't enabled.
Rail
Clicks and Pops During Playback and Record (Not a Buffer Issue) | SamRisen | Windows | 10 | 11-11-2013 05:44 AM |
MBox Mini/Pro Tools 10 playback/record issue | Ewan T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-11-2011 03:54 AM |
Weird playback/CPU usage issue with PT9 | MetalGarret | Windows | 18 | 06-22-2011 06:08 PM |
Weird Record Issue with PT 7.1 CS7 | 25ghosts | Pro Tools TDM Systems (Mac) | 2 | 05-28-2006 06:44 AM |
Weird quicktime playback issue with 002r | crazyfoo' | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-09-2006 01:09 PM |
