Mbox USB problem
I'm using an Mbox with a new ibook and I use the 6.1 and 5.2.1 version. I have a Midiman Oxygen 8 midi controller. Using PT 6.1 and OSX, everything works fine, without even requiring any driver. In OS 9.2 I installed the oxygen 8 driver and when I run PT 5.2.1 LE and open a midi track, the USB controller shows up just like with 6.1 and OSX, but no midi gets onto the track. Any ideas????
Re: Mbox USB problem
Did you configure it correctly using the OMS application?
Is your device enabled as a MIDI input device at Pro Tools' MIDI menu? |
Well, I set the midi input device in the midi menu to "keystation series" and configure oms midi setup detects that device with that name and the track input and outputs show the same thing also. I think if anything is set up wrong, the track inputs and outputs won't show the device in the pull down menu. Everything looks just like it does with OSX and 6.1, but with 9.2 and 5.2.1 it doesn't work.
Mbox 2 Pro crashed Pro tools 11.1.2 - Solved problem bought new Mbox 3 ;) | shamanrock | Pro Tools 11 | 0 | 02-15-2014 03:36 PM |
MBOX PROBLEM PLEASE HELP! | shanepjones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-09-2007 04:00 PM |
Mbox to Mbox 2 Pro upgrade problem | Zumwalt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-08-2007 12:58 PM |
Help: Problem with MBOX 2 | Bouni | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-21-2006 06:16 PM |
mBox problem- help! | Billy Claire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-18-2002 01:47 PM |
