Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 01-23-2021, 01:58 PM
bonzerboy bonzerboy is offline
Default Plug in chain Console question
Hope this is the right section. Anyways so I see these SSl or any otherconsole plug ins and I was curios if you have a gtr track you like with amp model software or maybe it was a EQ and a compressor and you like that over all sound. If you wanted to try to get the Console sound would that be ok to put that plug in after ? I am thinking of it as that is my source. Hope that makes sense.
Wow am I groovy or what
Old 01-23-2021, 02:33 PM
danyg danyg is offline
Default Re: Plug in chain Console question
having a good education in signal flow and analogue routing is a good thing.
however it's 2021 and why would we like to reproduce every old school technique ITB - do whatever you want and make unusual chains, be creative
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 01-23-2021, 02:48 PM
I get that . My thought process was ok i have a track sounding good. Would i treat that as a source as going into a board.os adding the console plug in after
Old 01-23-2021, 05:51 PM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is online now
Well what more does the track need? I mean if you have the track sounding as you like it, what more does the track need? As has been said many times, if it sounds good it is good.
That said, put it wherever you want. If you like it, cool. If not, try something else. Signal chains can make huge differences in the sound because of how they feed from one to the other.
Just my opinion.
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
Old 01-24-2021, 02:44 AM
Let me ask it like this. Say your the guitar player, you add what ever you add t make your sound. That would be your source correct. If you were going to a real board you would then input into the board. I want to see if this s the same process using console software.
Old 01-24-2021, 04:27 AM
That's a good way to go for using a console/channel strip plugin. Replacing that big clunky SSL 4000 heat generator with a channel strip ITB. For example if I'm using a softsynth I feed that into a channel strip emulation and processing is after that strip. Where it gets complicated is if I want to use an outboard compressor plugin before the strip's eq; that's when I go synth to compressor to strip. If I stayed with the strip's compressor I could just switch the order around inside the strip plugin.
Jack
QAPLA!
Plug-in upgrades/mastering chain advice? sparky3000 Post - Surround - Video 3 06-12-2013 03:22 PM
Side Chain Arriving Late to RTAS Plug - Delay Comp On holden Pro Tools TDM Systems (Mac) 33 04-23-2012 11:51 AM
Master Plug-in Chain reycantong Tips & Tricks 34 12-06-2009 01:45 AM
Plug ins chain French links Tips & Tricks 6 08-10-2006 04:53 AM
What's Your Plug-In Chain on the Master Fader??? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 22 04-14-2004 10:12 PM
