Old 01-23-2018, 07:16 AM
Liam8mail Liam8mail is offline
Default Kontakt 5 multiple outs crashing protools
Right so, i'v one kontakt 5 plugin on an Instrument track that is running serveral instances all routed out to seperate audio tracks. Doing this should release a lot of cpu power as opposed to running serval instances of the plug in. But doing it this way is actually crashing my protools. I'm baffled but i know i'm not the only one having this problem via google searching.
It's a simple configuration, small session yet cpu is overloaded...
Pro Tools 12.8.2
M-Audio M-Track Plus
Windows 10 - 64 bit
i7 6700 HQ
16 GB RAM
Old 01-23-2018, 07:48 AM
john1192 john1192 is offline
Default Re: Kontakt 5 multiple outs crashing protools
Pro Tools 12.8.2
Windows 10 - 64 bit
i7 6700 HQ
16 GB RAM
i am a MAC person, but while you are waiting, are you (can you) use Kontakt Server on a PC ??
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-23-2018, 07:55 AM
Hi John,
I'm not sure what you mean by that.
Old 01-23-2018, 07:56 AM
amagras amagras is offline
Have you tried selecting a different setting for multiprocessor support? I have a core i7 so I have mine on 2 cores and it works fine.
Go to Options>Engine
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 01-23-2018, 08:12 AM
The cpu according to windows is around 20%. Protools says it's maxed out as it spikes from 10 - 100% every second. I do much or it will freeze or ask me to reduce my cpu usage. Under options tab i don't have the option of selecting 'engine'. Thanks
Old 01-23-2018, 08:18 AM
Hi, I don't have that option under options tab. There is no engine. Also window does not show my cpu at 100%.
Old 01-23-2018, 08:30 AM
Hi John,
in Kontakt Pref's (on my mac) there is a setting to use the Kontakt Server - otherwise the memory used is through your DAW .. Pro Tools in this case ..
do you not see this option in your K5 Prefs ???
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-23-2018, 08:47 AM
No i don't have that option as i use windows. Also i'm running 64bit and that option only applies to 32 bit anyway.
Old 01-23-2018, 09:31 AM
oh damn, i did not know windows and MAC versions were that different .. good info to know ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-23-2018, 09:36 AM
Actually yes those option are in the interface for kontakt 5, I thought you were talking about the DAW. I have changed them but no difference. The problem is imo not cpu related but when i route the outputs channels of kontact to protools tracks. It basically freezes or responds extremly slowly. I can run multiple instances of Kontact no problem on seperate audio tracks.
Kontakt & multiple outs (to PT aux inputs) Jussi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-29-2009 03:15 AM
Multiple outs from KONTAKT vicwind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-13-2005 02:20 AM
Kontakt multiple outs and PT 6.7.???? Valeri Pro Tools TDM Systems (Mac) 4 11-03-2004 05:48 PM
Kontakt Multiple outs into Protools Tim R. Pro Tools TDM Systems (Mac) 22 12-08-2003 07:17 AM
OSX Multiple Users Crashing ProTools relaxo Pro Tools TDM Systems (Mac) 0 07-18-2003 06:26 AM
