MEMORY ERROR MESSAGES- Strange memory loss
Hi I wondered if anyone else has experienced this problem.
I load up a couple of VI's Kontakt x2 BFD x1 Omnisphere x1 I try to load a patch and I start getting error messages saying not memory left to load the sounds and try to to use lite versions or reduce plugins .... I then close pro tools and then reopen session and then it continues as normal and i can load the exact same patch that i got the previous message about ? HAs this happened to anyone else and is this a bug ??? Is there a workaround ? I am running Pro Tools 8.0.4 on a 8core 2.4 Mac Pro Westmere new model Please advise Many thanks |
Re: MEMORY ERROR MESSAGES- Strange memory loss
Please guys any help ???
No help from anyone how unfriendly ?
I have experienced something like this before. It happens occasionally when i have the same plug-in open on about 7 or 8 tracks. An error message pops up and says to close some RTAS plug-ins due to me not having enough memory, and to up my CPU usage in the Playback Engine.
I unfortunately dont know the solution to this problem. The only fix i've been able to do is to bypass some of the RTAS plug-ins when i dont absolutely need to listen to that track. Its a pain in the a**, and would like some solution too. |
This is partly why these kinds of posts get no replies. Do some of your own homework folks...try some things before getting on here and asking a question with no information and then criticizing the folks here for not answering. Go to the top of the front page of this sub forum. Go to Customer Assist and try following all the optimization info there on video. Make sure you have a separate audio drive. Find out how many processors it is best to use on a computer like yours. How much memory do you have? Have you trashed prefs and repaired permissions....... etc go through all the stuff about turning off Spotlight and Airport, disable journal indexing all that stuff and also make sure all your plugs are approved and up to date.
Mac Studio M2 Max 12-core CPU, 38-core GPU, 16-core Neural Engine 64 GB memory 2TB Solid State Drive Thunderbolt 4 Sonoma 14.1.2 Pro Tools 2023.9 Universal Audio Apollo 8P (TB3 Option Card installed) |
it´s the case that Pro Tools still runs w/ 32-Bit and therefore has the 3GB-limit. If you load in samples in Omnisphere, etc. the 3GB limit is very fast full. You can e.G outsource the memory load of the Virtual instruments. E.G. in Omnisphere you can go to the system page>Streaming>Mode>put this to server and the loaded samples are not counted to Pro Tools aquired memory and Pro Tools has more memory headroom. We are waiting for the 64-Bit version so that the memory aquiring limits are past then. I hope this helps. |
What is strange is that I can use Omnisphere all day and perhaps with an instance of Trilian and Superior Drummer or Drumcore. But if I try load Xpand,even if it is a brand new session and Xpand is the only instrument up, I get the 9006 error and the plug in goes to inactive.Done. No way out.
I am going to try that with Omnisphere. I did not know that. Thanks.
Kontakt Memory Server (KMS) Could not start MemoryServer. Memory Extension will be... | John_Toolbox | Virtual Instruments | 5 | 12-29-2011 10:03 AM |
Memory Error Messages -Please Help | hwill2008 | Pro Tools 9 | 25 | 03-28-2011 08:35 AM |
PT 8 LE: Windows Vista Memory Loss | Valley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-28-2009 10:16 PM |
Promting lack of memory on PC with adequate memory! Any tips? | will22 | Digidesign Hardware & Software | 12 | 09-20-2001 08:36 AM |
running out of memory for strange reason... | naman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-26-2000 10:32 PM |
