Bass guitar chain and vocal chain??
Just wondering what peoples go to chains are for both bass and vocals.
For vocals do you compress on the way in? if so what comp and how much. Same for bass what are people doing there on the way in, compressing? If so with what and how much My vocal chain is normally AC1 H-EQ (Subtractive) C4 SSL E Channel (Colour) LA2A 1176 API (Colour) The last 3 are used in some sort of combination. Might be all 3, might just be 1 of them. My bass chain is AC1 H-EQ (subtractive) 1176 SSL E Channel (colour) API (colour) And I will sometimes blend a duplicated bass track in with decapitator on and less bottom end and more mids So what are you guys doing for these tracks Sent from my iPhone using Tapatalk
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Bass guitar chain and vocal chain??
I just got the Reinassance Maxx so I'll be using that everywhere for a month or until I get something else. The last vocal I mixed was F6, PuigTec, CLA2A, sometimes CLA76 after, Trans-X and NLS
I'm through the Waves phase
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Don't know what AC1 is My usual vocal chain:
mic(Miktek C7 or CV4 usually) Preamp(API 312 clone) Compressor(Warm Audio Wa2A) plugin chain: Melodyne(if needed) EQ III 7 band(highpass around 125) BF76(touching peaks) SMACK!(more compression with character) Waves Puigtech EQ on a tough track, I might stick Waves Vocal Rider up top and maybe add a de-ess before the pultec. Sometimes the entire chain gets swapped for Slate VMS(try to pick the best chain for the voice in question) Bass-DI>Vintech 573>Retro Doublewide plugin chain: EQ III 7 band(low shelf cut and a bump around 900) Waves Bass Rider(if player is not consistent) BF76 Waves JJP Bass plugin AUX send to AUX track with Amplitube SVX(usually B-15 with tweaks) I track the bass without JJP(too much latency) and when mixing, the amp sim gets a stompbox distortion pedal(sounds bad while tracking, sounds awesome in a mix).
Vocal - Miktek CV4 > Portico 5012 > McDSP FB > McDSP AE400 > Softube FET
Bass - UA 6176 > Softube Tube-Tech Classic Channel > bx_opto (maybe)
@Albee AC1 is McDSP plugins :)
I see you guys have shown your chain from the mic so I’ll add that to Warm Audio U87 Liquid Channel (neve 1073 and la2a settings normally comping 4db on loudest parts) Then into ProTools, with my plugin gain How much gain reduction are you guys recording on Vocals on the way in ? Sent from my iPhone using Tapatalk
Raoul Crane
Best to keep GR gentle on the way in(3-5db). You can always add more ITB, but if its crushed going in, it will always be crushed
Today it's "urban funk" day! We're using:
Vocal - SM7b -> API 3124 -> UA 1176LN. Plugins: Slate VMR AirEQ for shelving, Distressor for grip and presence. Equilibrium as needed. Melodyne for tuning. Bass - MD421 -> API 3124 -> DBX 160XT ("Over Easy"). Plugins: Same as above. |
I find I need a little compression on the vocal to keep it even while tracking.I don't think you can do wrong by putting a 1176 on your bass while tracking
vocal chain outside the box | chalz2502 | Tips & Tricks | 5 | 08-13-2014 02:40 PM |
What is on your Vocal Bus Chain?? | Rayvenx2208 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-22-2010 02:20 PM |
OT - Help with VO vocal chain | vocalvoodoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-04-2005 02:26 PM |
Vocal Chain | S_w_a_m_p | General Discussion | 6 | 07-25-2005 03:45 PM |
vocal efx chain | mudflaps | Tips & Tricks | 3 | 05-26-2004 07:23 PM |
