Old 04-04-2018, 10:24 AM
GCScott GCScott is offline
Default Latch prime in trim mode
Hi.
We're running pt 2018.3 and S6 software 3.7 with the compatibility softkey appset patch.
Are you able to confirm there is no ability to 'auto match' in trim mode using the 'F' button. I've checked the 18.3 fix list and it doesn't seem to mention it so perhaps it's just not a function.
An example:
You have single track in latch and Pro Tools set to latch prime in stop.
If you move the fader still in stop, and then hit the 'F' key above the fader (the one that cycles automation modes) the fader will auto match back to the start. Great.
Now also put that track in trim. If you move the fader while in stop, the 'F' key now cycles automation modes - no longer 'auto matching' - the only way to 'auto match' to the trim is to use an 'auto match' eucon command (or in the PT).
I'm convinced that in prior iterations of the workstation the 'F' key would behave as it does when the track isn't in 'trim' - as an auto match.
Can you confirm for me this is operating correctly? Perhaps I'm missing an tick box somewhere?
Best,
Old 04-05-2018, 09:28 AM
EddieJones's Avatar
Default Re: Latch prime in trim mode
We added a bug and will try and fix this. Thanks
PT Stuck in Prime for Playback mode dj_grimmace Pro Tools TDM Systems (Mac) 7 11-23-2012 08:04 AM
Cant find "allow latch prime in stop" anywhere??? cocamycola89 macOS 2 02-17-2012 12:33 PM
PT stuck in Prime for Playback mode dj_grimmace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-19-2009 09:13 PM
7.2 automation offline Latch prime bug Steve MacMillan Pro Tools TDM Systems (Mac) 2 08-22-2006 02:06 PM
Latch or touch and trim beech ICON & C|24 3 10-10-2002 10:15 AM
