Old 01-05-2015, 02:00 AM
montreal montreal is offline
Default Migrating from one DAW to another...
Hi all again. (and may talent be with you for this new year !)
As you prolly all know now im a technical noob for life......so.......i have another question... :O)
Lets say you want to migrate MANY sessions from PT to Logic or conversely, what the most quick and efficient method to do that please because im not so sure... ?
Old 01-05-2015, 03:46 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Migrating from one DAW to another...
Select whole timeline from zero to last note, then consolidate all tracks. Import the tracks to another tracks like importing audio from analog tape.
Janne
Old 01-05-2015, 07:26 AM
OK thanks.
You mean if i have 20 tracks in a session i must;
1/ create 20 tracks (stems ?) then;
2/ import those 20 tracks into the new DAW then;
3/ identify and recreate each audio files on those 20 tracks ?
Old 01-05-2015, 07:52 AM
Mattiasnyc Mattiasnyc is offline
OK thanks.
I think he meant:
1) Select a starting point in the time line, select all tracks, select all regions
2) Consolidate all regions into one region per track
3) Export all of those newly created audio files into a folder (if you want to keep it neat)
4) Import all of those audio files into the other DAW and line them all up to the same starting point
Old 01-05-2015, 07:55 AM
Kirby B. Kirby B. is offline
I think that it is the only way to do it. You can consolidate them all at once. Label them and Montreal's step 3 is not hard. Seems like someone should have a handy program for doing it an easier way, but I don't know of one.
Last edited by Kirby B.; 01-05-2015 at 07:56 AM. Reason: newer post in the mean time
Old 01-05-2015, 08:45 AM
Craig F Craig F is offline
that is not a Stem, a Stem is a sub mix that when combined with other Stems makes the whole mix without the need of adition proccesing other than voulume rides if the Stem is an un-dipped Stem
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 01-05-2015, 08:50 AM
Consolidate and export is also a great way to backup your work. Assuming going FROM Logic and TO Pro Tools, naming the files as you export would mean, upon import into PT, and assuming you "import to new track", the tracks will be named as the files are Of course, midi can also be exported, but if you have a VI in Logic that you like the sound of, I would also record to an audio track and export both.
Old 01-05-2015, 08:51 AM
upscaps upscaps is offline
Originally Posted by Mattiasnyc View Post
I think he meant:
Indeed. I will add #3B. Do mono tracks and stereo tracks separately.
Old 01-05-2015, 11:06 AM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
The consolidate and export is one way.
The other is to export as OMF
1. Select all track names that you want to move to Logic
2. Choose File -> Export -> Export as OMF
3. Choose "Separate Audio" not "Consolidated"
4. Export
5. Open the OMF as a session file in Logic.
The benefit of working this way is that you still have access to all edits in the timeline. The file size is also much smaller.
Keep in mind that no matter what you do, no effects or instruments will transfer over unless you commit them to a track first.
Sign up for all things....AWESOME!
Kris
May the music move you
Old 01-05-2015, 11:10 AM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
When I moved sessions from MOTU's Digital Performer to Pro Tools I utilized DP's OMF export and imported into Pro Tools. Same for Logic sessions - OMF.
All audio pieces were brought in and put in the right places.
I have never tried Pro Tools' OMF export.
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Migrating fm PC -> Mac CrazyFingers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-16-2010 12:52 PM
Migrating PT8 HD to PC ammusicco Pro Tools TDM Systems (Mac) 13 09-20-2009 07:10 PM
Migrating LE6 (pts) to LE 7 (ptf) otravox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-01-2007 04:03 PM
Migrating to Mac from PC... Wheeltard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-11-2006 12:16 AM
migrating from a g4 to a g5 willbgoode Pro Tools TDM Systems (Mac) 0 10-05-2004 06:36 AM
