Re: Recording MIDI on ProTools
I have the same problem with Motif 7,002 le 6.9and mac osx tiger10.4.3. Though midi I can get a sound source and even record it but unable to hear pre or post record.Using the motif through the line/instrument inputs gets a good signal but thats a poor second option.Any ideas?
Same problem here on Windows 2008 with ProTools 7.4.2 CS7 and an Audiophile 2496. the Midi Input Enable list is empty and no idea how to recover from there: 1. Uninstalled / reinstalled : did not work 2. Removed QuickTime as suggested from the thread owner : did not work 3. updated Delta Audiophile 2496 to the latest drivers: did not work Please do something because I am stuck and cant work here! ** Note dont believe Windows 2008 instead of Vista makes any difference, moreover Garritan can nicely work via midi with the M-Audio card and sounds nicely. |
#16
I'm trying to be nice here, but really I made the Help Us and General Troubleshooting threads for a reason - to save myself and everyone else here from retyping the same things over and over again. If you don't care to avail yourself of the information provided in those threads and give us the information we need to help you, there's not much more we can do for you. |
#17
This sounds like the exact problem I am having...It just appears that PT doesnt want to accept any midi input coming in. That and I cant get reason to "see" my keyboard...But it works on the Mac side of my dual boot computer...huh?
MacPro 2.8 (8X) OS...10.5.6 (Mac) Windows 7 Ultimate 10GB Ram 640GB(Mac) 640GB(Windows 7) 1TB(Audio Drive) Digi-002 Factory and M-box LE 8.0.3 (Mac) 8.0.3 (PC) |
#18
Pro Tools/Reason/Mac OS X 10.5.5 Audio MIDI Setup Not Recognizing Any MIDI
Information:
Mac PowerPC G5 Dual 1.8ghz Mac OS X 10.5.5. Leopard Pro Tools 7.4.2 2gb Ram 002 Rack Yamaha MIDI keyboard model: Yamaha YPT-310 I am having the Exact Same problem as Digifriend above this post. My ProTools won't recognize a MIDI signal coming in despite the green light flashing on the front of my 002R. I was running my MIDI keyboard in protools in a session that had worked fine before with all my MIDI connections correctly set up and using sampletank1 to see if the MIDI would work. It didn't. I first recognized this problem when I was trying to run reason standing alone and it wouldnt recognize any MIDI. I had my keyboard routed through my 002R. Specifically it said the "port 003 control [offline]" in the advanced section of Reason 4.0. I also had reason scan for my controller, and it found nothing. Tried to manually add the keyboard but it could not recognize a midi signal. I went to the Mac Audio MIDI Setup and the 002R is dimmed out in other words it once recognized that it was there and now it does not. I don't know what to do. |
#19
Re: Pro Tools/Reason/Mac OS X 10.5.5 Audio MIDI Setup Not Recognizing Any MIDI
Similar to Digifriend's issue. I can get MIDI information out to my Alesis QS8.2 and have it played by the QS but I can't get anything to come in to PT from the QS.
Info:
MIDI record and playback has worked in the past (I followed the directions in the user's manual and it worked like a charm). Do I have an incompatibiliy with Quicktime 7.5.5 and/or Mac OS X 10.5.5? Thanks in advance for any help you can give me. |
#20
Your post is a little confusing - you say 'EZ Drummer and that works fine'. How are you using that? Is it inserted on an Instrument or Aux track? What are you triggering it with - the Alesis or with MIDI data that's already recorded? Quote:
This page has some good tutorials that may help you: http://ptnewbie.com/?p=56 |
MIDI recording in Protools | Sonic Blue Meanie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-04-2009 01:34 PM |
Midi recording via reason in protools????? | Gaz103 | MIDI | 0 | 12-04-2006 11:32 AM |
Digi, When Protools creates MIDI regions after recording MIDI info.... | Mt.Everest | Pro Tools TDM Systems (Mac) | 0 | 07-21-2001 12:12 AM |
MIDI Recording in Win98 Protools LE and keyboards...Can I use non-General MIDI sounds | Shan Plourde | General Discussion | 2 | 01-18-2001 08:34 PM |
OS 9,ProTools 5.0,MTP A/V,G4,MIDI recording? | James Cory | Pro Tools TDM Systems (Mac) | 2 | 03-22-2000 02:20 PM |
