Full-Screen Reference Video Without AVoption/MOJO
I'm putting together a small film post room along with a foley and ADR room next door. I need to be able to have the video reference window (quicktime) displayed in full-screen so I can split it and send it two places:
1 - On a large screen in front of my console for video ref. 2 - In the Foley/ADR room for spotting. Can this be done without the AVoption or Mojo? The editors simple want to send my quicktime files to reference, but is there a way to view them in full-screen? |
Re: Full-Screen Reference Video Without AVoption/MOJO
Get one of tha Canopus options. Cheak out the Post forum.
Rail
Hey Rail,
I guess I wasnt specific enough in my question. Can this be done when importing a Quicktime video? What you ask? Well, viewing the quicktime video in full screen. I'm not on ProTools|HD just yet, so I thought I'd ask. |
yes, the post & surround forum is a better place for this...
but i am confused, in your post over there about full screen video, you were given several options beside mojo and AV option. what didn't you get about that advice? i am not being snide, i am honestly trying to help. ...and, not that i like contravening rail, but i would avise against a canopus -- too much latency, drift, lousy scrubbing, and takes its own FW port. the FUSE-X (which was suggested to you in the other forum) is almost as cheap! but better performance -- and plays more codecs! FUSE-X
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
The reason I posted this here is because this is more of a general HD functionality thing. I don't personally use an HD system (yet), but I have worked on many in commercial studios. My question is regarding the fuction of the Quicktime window in PT. Can I route this window to a seperate screen and blow it up full-screen?
If the FuseX card can do this - that's great! But how? Does the FuseX actually intercept the quicktime video and output it via the PCI card? |
hi,
yes, well, the suggestion was to go to the post forum, where people do mix to picture ands edit to picture stuff. this TDM forum is more general how to use and problems with TDM systems in MAC OS. but, both post and non-post people hang out here....... and to answer your question, yes. the FUSE-X will go in a PCI slot -- hopefully you have a free one and work woth your MIX or LE system. you import the QT into Pro Tolols and the movie will play out the FUSE-X card. in fact, anything you play in QT will play out the FUSE-X card. even 24fps movies, which it does by means of duplicating some frames... don't know if i would trust it to really mix a 24fps movie with, but pretty cool. you sure could watch it. DV, DVC PRO, PO 50, H.264, Sorenson, MJPEGA, MJPEGB. etc......
Wow - thats great! The FuseX looks pretty neat. But you say you wouldnt trust it - how so? Is it too slow or latent? And if this is the case, this begs to ask the question...how do the big guys do it? Are they locked to an Avid system? What is it about this card that would make it not trustworthy? Thanks for the help
Just thought I'd mention another possible solution. Many Macs already have a dual-head monitor card in them. Some output SVHS as well, such as the Radeon 9800 shown here: Radeon 9800 Mac edition
You can output to either two monitors or a computer monitor and SVHS (composite adapter available if you need to split that signal through a video DA). If you have a plasma or LCD monitor with DVI input, the quality looks great. Does not take up a PCI slot. Will not capture, but if all you need is playback, a dual head graphics card works fine. Bob
Save early and often! (or once a day whether you need to or not...) |
we do this with an apple dual card. one goes to the computer monitor, another goes to a splitter.
the splitter goes to a second monitor for the control room, the second signal goes into a little vga -> rca converter and into a tv. simply set the second monitor resolution to 640x480, drag your movie window to it, and click it to open full screen. you won't have perfect sync action(tm) but it is plenty good enough for adr/foley. |
Anyway to Full Screen the video inside PT LE? | Rockman413 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-18-2009 05:19 PM |
How to set up a video reference screen? | spicyitaliano | Post - Surround - Video | 8 | 02-20-2006 07:55 AM |
Full screen video playback with PT | Paul Maunder | Post - Surround - Video | 22 | 11-12-2005 05:51 PM |
I'm getting full screen mpeg video!!! | SeanDerMan | Pro Tools TDM Systems (Win) | 0 | 11-07-2005 02:09 AM |
6.1 and full-screen video | espron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 08-20-2003 09:23 PM |
