Old 02-19-2018, 05:32 AM
BrianE BrianE is offline
Default S3L plugin install problem
I bought the Disto-s plugin from SKnote, with AAX-DSP. And did everything what the manual said (see below), but when I copy everything to an USB (exFat) the s3l wont read the USB...
Guide from SKnote:
SKnote Disto-S AAX.
Installation.
- Create a "SKnote" sub-directory in your plugins folder.
- copy the content of the downloaded zip file to "SKnote" directory. You should see "Disto-S_Original.aaxplugin" and "Disto-Sd". Rename "Disto-S_Original.aaxplugin" exactly "Disto-S.aaxplugin". Keep Disto-Sd with the plugin.
- Launch ProTools. Insert Disto-S in a track and open the interface. It will self-install.
Check: your name should be visible in the bottom-right corner on the interface.
To install on Venue console.
- Install on Pro Tools.
- Launch the plugin from inside Pro Tools. Check your name in the bottom-right corner.
- Close Pro Tools.
- Copy the plugin from Pro Tools to Venue.
Enjoy and please help to protect the software.
Old 02-19-2018, 06:19 AM
Valentyn Valentyn is offline
Default Re: S3L plugin install problem
Do you put it into USB in the following way
<USB Drive>:\AAX Plug-Ins\Disto-S.aaxplugin
Old 02-20-2018, 06:25 AM
Yes. And it reads the USB stick, but when I select the usb stick, nothing appears..
Old 02-20-2018, 06:30 AM
Tried putting it in
USB:\AAX Plug-Ins\Disto-S.aaxplugin
USB:\AAX Plug-Ins\SKnote\Disto-S.aaxplugin
USB:\Plug-Ins\Disto-S.aaxplugin
USB:\Plug-Ins\SKnote\Disto-S.aaxplugin
Old 02-20-2018, 08:47 AM
Acousticwarrior Acousticwarrior is offline
First install and open in Pro Tools, then go to plug in folder and copy the content including the file called COLISA, then paste manually in the plug in folder on your S3L-X via desktop.
Then in plug in tab you should see the plug in under “prevoius installtions “ or “ plug ins on this console”, install on console from there.
Worked for me with multiple SK note plug ins and they all sound smazing!!!
They key is the dugital authorization file ( colisa) created by pro tools. Hope you can figure it out, otherwise e-mail Qunito Sardo at SK Note ([email protected] ) We need to support the people who help to improve this unique console, no other system is better suited for international fly dates.
Best,
Frank
Old 02-20-2018, 10:31 AM
RyanJ's Avatar
RyanJ RyanJ is offline
I'm not entirely sure this is relevant, but when you installed on Pro Tools, was it a Mac or PC Pro Tools?
Ryan John
Principal Product Manager | Avid Live Sound
[email protected]
Old 02-20-2018, 01:59 PM
Please tell me what files are in the Disto-S.aaxplugin folder and subfolders? Could you post screenshots of the folder structure inside?
Old 02-20-2018, 02:00 PM
Good question! Must be PT on Windows, otherwise it should not be recognized.
Old 02-20-2018, 09:32 PM
Karel Noon Karel Noon is offline
You don’t even have to do the protools install, you can just unzip the files and copy them to the usb stick to check if it works.
Take care: you are missing your name in the plugin that way, stating that it is licensed.
Old 02-22-2018, 12:48 PM
Yeah, it was on a mac. Weird enough it worked when I copied the Windows version of the aax plugin..
Thanks for the help.
Waves plugin install problem PyneBoxx Pro Tools 11 6 09-07-2014 11:22 PM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 07:23 AM
ELS Vocoder plugin problem and fresh Windows 7 install problem Thorpey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-09-2011 05:03 AM
How can I un-install an unwanted plugin? pipeorgan Pro Tools M-Powered (Win) 0 11-30-2010 03:09 PM
How to install plugin?? sck312 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-10-2003 05:58 PM
