7.4.2 no inputs
Downloaded 7.4.2LE running with MBox and OS 10.5.3, and no sound is getting from the Mbox to Pro Tools. I can hear sound on the input side of Mbox, but no sound is going to the Mic/Line inputs of my session. When I check the sound prefs on the Mac, the MBox is not showing up as an input. When I launch Digi Core Audio Manager, is says the hardware is in use by another application. Have trashed all pro tools prefs.
Any suggestions? Mike
Michael McDonough, M.P.S.E. Michael McDonough Sound Design |
Re: 7.4.2 no inputs
1. Have you tried resetting the default I/O (set-up menu) in case that's messed up?
2. What about toggling input only monitoring? 3. Monitor mix halfway? Launching CoreAudio whilst PT is open usually does result in a 'hardware in use' error. http://www.myspace.com/philogg |
Re: 7.4.2 no inputs
Tried all that. No inputs still. PT 7.3le worked fine all the time with same set up. Any other suggestions?
Mike
Using Eleven Rack inputs like POD X3 inputs | dayslypper | Eleven Rack | 1 | 10-09-2010 09:15 PM |
Analog inputs 5-8 not seen as inputs on tracks | sitarartist | Pro Tools M-Powered (Mac) | 4 | 09-16-2010 08:24 AM |
How do I utilize the Line inputs when all my XLR inputs are being used? | 007audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2009 08:21 PM |
inputs | ardiemizzou | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-13-2006 09:19 AM |
001 vs. 03D inputs | Alvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-13-2002 07:16 AM |
