Old 09-14-2017, 02:22 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default Re: LtRt AAX plugin
It's just historic lazy cut & paste
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 09-14-2017, 11:48 AM
marsian marsian is offline
Hey,
I'm in need of a LtRt Plugin, too. I think the cheapest way of doing it is with the Dolby Atmos Production Suite for 299$.
Could anyone confirm this?
Cheers
Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D
mars13.de
Old 09-14-2017, 10:01 PM
smurfyou smurfyou is offline
Originally Posted by marsian View Post
Hey,
Cheers
Maik
I thought that was just for Atmos production.
I use Surcode, simply because it's what I bought when we were moving away from hardware years ago.
~Will
Old 09-15-2017, 11:26 AM
MatzeHD MatzeHD is offline
This or Waves360-surround-tools, with many stuff and the good M360 Surround Manager & Mixdown!
https://www.waves.com/bundles/360-surround-tools
Old 09-15-2017, 02:23 PM
ChrisMac ChrisMac is offline
that doesnt do LtRt only LoRo
Chris McIntosh
President/Sound Supervisor
Postal Audio Inc.
Imdb
Facebook
  #16
Old 09-15-2017, 04:27 PM
You are sure?
I do not use it until now, but if I look in the user guide:
https://www.waves.com/1lib/pdf/plugi...0-surround.pdf
You have many posibilities and I think you can make with the Phase Option, Panner’s and Imager’s a LtRt downmix too, I looks like this! :)
Yes, otherwise SoundCode or Minnetonkaaudio SurCode will works good too! :)
Or if you have no money, you can make the encoding manually, its not so difficult!
  #17
Old 09-17-2017, 07:21 AM
minister's Avatar
minister minister is offline
You are sure?
We are. If you read the user guide it doesn't mention encode/decode, it only mentions Stereo (ITU) which is NOT LtRt.
Yes, you can do it manually.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
  #18
Old 09-17-2017, 09:10 AM
simonyeah simonyeah is offline
Can someone explain how to do it manually (both encode and decode)?
Envoyé de mon iPhone en utilisant Tapatalk
  #19
Old 09-17-2017, 10:30 AM
In the Wavetools are no a directly preset, but I thought you can build this with the options?
Encoding manually
Decoding is difficult, if you want to listen the downmix in Dolbymode, you need a external reciever or a dolby decoder plugin.
Encoding here:
Creating an LtRt signal is very similar to creating LoRo--at first. The LFE channel is discarded, then left channel and center channel (at -3 dB) are added, and then the right channel and the center channel (at -3 dB) are added. Handling the surround channels marks the point of departure from similarity. Left surround and right surround are added together to create a single "S" signal. This S signal is added out of phase (180 degrees) to the left and center signal to create Lt, and added in phase (zero degrees) to right and center signal to create Rt.
http://www.tvtechnology.com/audio/00...nd-ltrt/185096
  #20
Old 09-18-2017, 06:17 AM
Many thanks
HTML code is On
LtRt Question sonichead Post - Surround - Video 8 09-03-2013 01:45 PM
5.1 to LtRt zzstation Post - Surround - Video 3 05-25-2012 12:19 PM
Neyrink LtRt plugin: container lululu Post - Surround - Video 4 08-12-2011 09:06 AM
Some LtRt quesitons Newpostguy Post - Surround - Video 11 08-18-2010 06:08 AM
How do i create an LtRt mix from 5.1? Andy Hay Post - Surround - Video 18 11-08-2004 09:46 AM
