How to Join & Post    Community Terms of Use    Help Us Help You
Knowledge Base Search    Community Search    Learn & Support
Old 12-14-2012, 12:54 PM
arvid.lind arvid.lind is offline
Default Installing Lion from MB pro to Mac Pro...
Scenario: Im on SL 10.6.8 on my Mac Pro. Having problems within protools, but general problems with OS X as well; Kernel panics etc. Orginal SL dvd missing. Have bought Lion via app store, but didnt install. Now Lion is withdrawn from appstore.
Installing from my Macbook Pro with Lion 107.5 via the command + R option, having my Mac Pro in target disk mode, seems quite dangerous.
ML is not an option since Im on an unsupported Mac Pro (late 2008 harpertown)
Any opinions is appreciated!
arvid in stockholm
Studio:
PT HD 2018.1 | HDX1 with Omni in Sonnet chassi | MacPro 2013 6-core 24 GB ram | OSX 10.12.6 | 2 x Avid Artist Mix
Old 12-14-2012, 01:24 PM
Chief Technician's Avatar
Lightbulb Re: Installing Lion from MB pro to Mac Pro...
Put your MBP in Target Disk Mode, boot your Mac Pro from the MBP, and use Carbon Copy Cloner to get the OS from your MBP onto your Mac Pro.
Old 12-14-2012, 01:49 PM
Default Re: Installing Lion from MB pro to Mac Pro...
So, Im repeating just to be sure, I put my MBP in target disk mode, and from my Mac Pro I make a CCC-copy of the harddrive of the MBP? And how do I proceed with the installation or copy process?
Im buying a ssd drive tomorrow to make a new internal drive on the Mac Pro with this installation.
Studio:
Old 12-14-2012, 02:16 PM
minister's Avatar
minister minister is offline
If you are having system problems with the Mac Pro, start by running Cocktail and Disk Warrior on the system disk. If it repairs some things, see how that gets on.
The next step is to clone your disk with Super Duper, then reinstall 10.6.8.
You can buy an SL disk from Apple (I realize you are in Sweden, but maybe there is a Euro-Apple?).
http://store.apple.com/us/product/MC...6-snow-leopard
Personally I would do ALL that BEFORE I went to LION.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 12-14-2012, 02:33 PM
Thanks Minister Of Fancy Noises! Yes, but 3 weeks delivery time for the SL disc.
Will do that.
My (music/logic)colleagues have been warning me about Lion, but actually PT works great on my MBP with Lion. But on the other hand, Pro Tools has always been more stable on my laptops than on my main desktop computers, Iv never had a single crash with PT on a laptop.
Thanks a lot.
Studio:
Old 12-14-2012, 03:58 PM
Yes.
Installation or copy process of what? The CCC process will clone your MBP to your Mac Pro. Unless you have additional data or software that you need on the Mac Pro that is not on the MBP, you will be all set once CCC is finished.
In that case, use CCC to clone the MBP to your SSD.
Old 12-14-2012, 04:45 PM
minister's Avatar
I run routine maintenance (like once a month) on my computers which consists of :
Zapping P-ram -- I am told the need for this did not stop in OS9 -- restart computer and hold Cmd-Option-P-R, let the startup chime go at least 3 times.
I run Cocktail to repair disk permissions, run cron scripts, clear caches.
Disk Warrior on all drives including system -- for the last one you have to boot from the disc itself. If the report comes up red, replace and run again until green. No need to save the report.
There are other utilities to do this, but those are the ones I use. Besides, Cocktail is made by a Swede!
Try all that FIRST.
Maybe you can borrow copies of Disk Warrior and Snow Leopard??
Tom Hambleton CAS
IMDb
-Starcrash
Old 12-14-2012, 11:13 PM
mikevarela mikevarela is offline
not positive, but the mac pro and MBP are not the same systems so cloning won't work. different libraries based on hardware dependencies.
you can only install same or higher OS's when using target disk. going to lower versions doesn't work.
apple isn't to crazy about sharing OS versions with friends. they have been more concerned about getting people on the latest versions. if you know anyone that also has a mac computer ask if they have a copy of SL.
lion works well on most computers, ML not so well.
SL is very stable though so best to try and do a reinstall of that. I usually wipe my macs once a year and do a fresh reinstall. its crazy how fast they get after the reload.
if you're concerned about data, for sure, run the pro in target and get a clone of it with CCC.
NuanceTone.com
Old 12-15-2012, 05:34 AM
Yes.
OK, thanks Chief! Still reluctant whether to install SL or Lion, but if I go Lion Ill install on a separate drive.
Thanks, Im familiar with the PRAM-zapping, but hadnt heard of cocktail. Have been trying to aviod these disk repair applications since I ran into one that caused more problems than it solved.Dont recall the name. But Im trying Cocktail now, see if it will make my system healthy again.
Since I often use my (home) MBP to clean up OMFs and record finished mixes to track, Im thinking that it would be wise to have the same OS X on both computers. Too much travel beteween two OS X versions might corrupt my sessions.
Thanks for the input everyone!
Arvid d;-)
Studio:
Old 12-15-2012, 07:34 AM
Cocktail seens to have fixed my problems for now. Seems like a great application! Thank you Sweden, and Minneapolis!
Studio:
HTML code is On
Installing PT9 on 10.8.2 (Mountain Lion) mauruiz macOS 2 12-04-2012 03:14 PM
Need help Installing PT9 on Lion mathbishop macOS 2 02-20-2012 12:25 AM
installing PT HD9 from DVD on lion Justinp Pro Tools HDX & HD Native Systems (Mac) 1 12-17-2011 05:47 PM
Installing PT HD 9 on Lion 10.7.2 Coolchris77 Pro Tools TDM Systems (Mac) 2 11-24-2011 07:10 AM
trouble installing PT9.0.5 on Lion willie66 macOS 4 09-02-2011 11:18 AM
