Old 12-03-2012, 05:34 PM
mauruiz mauruiz is offline
Default Installing PT9 on 10.8.2 (Mountain Lion)
Hi.
I have purchased a new computer, that comes with Mac OS 10.8.2 installed.
I'm trying to install the full PT9.0.5 pack, to after upgrade it to 9.0.6.
But, the instalation of the 9.0.5 just doesn't starts. The icon keeps bouncing on the dock.
I have tried to run the installer directly from the /System/Library/CoreServices/ but I can't open the 9.0.5 from it (it's greyed, like all the other installers.... that's strange).
What can I do??? Any solutions besides upgrading to PT10?
Installing the packages directly from the "show package contents" will work?
Thanks!
Old 12-04-2012, 01:44 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Installing PT9 on 10.8.2 (Mountain Lion)
Originally Posted by mauruiz View Post
Hi.
Thanks!
You need Pro Tools 10.3 for Mountain Lion.
Unless you can install /clone Lion on your mac and use 9.0.5
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-04-2012, 03:14 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
I just got 9.0.6 working on 10.8.2, but what I did was update a SL installation that already had PT 9.0.3 installed. Initially, pro tools showed up with the "no entry" symbol on it's icon, but after running the updater to 9.0.6, it seems to work fine so far.
It would appear that the 9.0.5 installer does not install directly to ML, but if it exists before you update to ML, you can run the 9.0.6 updater and get it working. Too bad there's no full installer for 9.0.6.
Since your mac shipped with 10.8.2, You probably can't install any older OS version. But, if you have another older mac, you might be able to get PT 9.0.5 onto your new one using migration assistant, then run the 9.0.6 installer.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
CPU overload after installing Mountain Lion tonyfirshman macOS 21 02-28-2013 04:56 PM
Need Help Moving Up To Mountain Lion And Fresh Installing PT 10.3.2 NBarnes21 macOS 12 12-08-2012 01:31 PM
Pro Tools 10 Crossgrade not installing on Mountain Lion penfold07 macOS 8 11-26-2012 03:31 AM
Pro Tools 10 on Mountain Lion HELP INSTALLING anulley macOS 0 11-01-2012 02:06 AM
Installing Pro Tools 9.05 on Mountain Lion rogerwilco2000 macOS 2 09-05-2012 10:33 PM
