Undo Record only deletes the Audio not Midi....?
when my separate midi generating computer is driving a softsynth plugged into a PT-Aux track via a PT Midi track armed to record, and the Aux track's output is bussed to an audio tracked armed to record, then the recording process inevitably records both the midi track and the audio track, although only the audio track will be needed....(I assume there's no simpler way to set it up)... so when I invariably need to UNDO the recording and record it over (e.g., to fix levels), the undo process only deletes the audio track, not the midi track which then must be manually deleted.... Isn't there a one-shot way to delete both the audio and midi tracks....? System: 6.2/Accel/G5
kirk |
pasting midi notes deletes others | Shatzer | Pro Tools M-Powered (Win) | 11 | 03-30-2014 01:22 PM |
Undo history deletes when a track is deleted | seafra | macOS | 0 | 10-28-2011 10:34 AM |
Undo Record Audio | Fix | Pro Tools TDM Systems (Mac) | 6 | 05-18-2011 06:30 PM |
Does PTF have a "undo record audio" function, help | Dither16bit | Digidesign Hardware & Software | 2 | 06-23-2004 02:14 PM |
I can't undo record audio, I CANT UNDO !!! | Dither16bit | Digidesign Hardware & Software | 0 | 06-09-2004 01:53 AM |
