Old 11-13-2000, 10:23 AM
recwall recwall is offline
Default signal Delay while trying to record
I know this must be a monitoring thing but I can't seem to find the thing to click on to lose the delay I hear when trying to monitor what I'm recording. Any ideas?
Cheers All...
Old 11-13-2000, 05:27 PM
BCBud BCBud is offline
Default Re: signal Delay while trying to record
I think the only way to reduce the Latency in Protools free is reducing the buffer size. Protools LE w/001 has a low latency monitoring option. But , of course they couldn't put it in PTfree cause you have to use 3rd party hardware.
To reduce buffer size go to Preferences>hardware and click and hold on buffersize till it gives the pop up window.
Or, if you have a console you can just monitor through that.
Old 11-14-2000, 12:06 AM
chriswebb chriswebb is offline
What sound card are you using?
Chris
Old 11-14-2000, 12:29 AM
QuikDraw QuikDraw is offline
Just mute the track that you have rec enabled. You'll still be able to hear yourself through your sound card (at least I am able to). That will eliminate the latency your hearing. Reducing the buffer will not work with many sound cards.
Mike
-- Mike
- MacBook Pro 15.4" (9,1) - 2.3 GHz i7 16GB RAM
- OS X 10.14.1 Mojave / Windows 10 (Bootcamp) - PT running on Windows partition
- PreSonus Quantum 2
- PreSonus Studio 24c
- MBox 3 Mini
- Mackie Onyx 1640i
- Behringer X32 Producer
- PT 2018.12 (vanilla)
- Various USB2/3 and Firewire hard drives
Old 04-06-2002, 08:09 PM
N. Pinto N. Pinto is offline
quote:
What if you're playing along to tracks you've already recorded? Are the playback tracks in sync with what you're playing in real-time? Or are they in sync with the delayed signal thru the monitors?
Thanks.
____________________
www.PintoMusic.com
Old 04-07-2002, 03:17 PM
Bastiaan Bastiaan is offline
That you will see if you play it back after you recorded it. If it is not in sync anymore, just nudge the track into place....
What's that?
- That's the machine that goes "pling".
Bastiaan
HTML code is On
No signal can't record theorganist macOS 1 12-02-2012 03:02 AM
press record.... delay... delay...now it records phanatik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-20-2007 03:20 PM
delay when pressing record or stopping record mrufino1 Pro Tools M-Powered (Win) 6 03-06-2006 09:29 PM
Not getting signal to record wagonburner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-20-2004 01:26 PM
Guitar signal delay Electrohermit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-11-2003 09:47 PM
