Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 08-06-2019, 05:49 PM
hitp hitp is offline
Default Monitor Page in PT | Control
Extremely exciting for me. But how do you use it?
Looking like you need an MTRX or Xmon. What if you don’t own either? If there is a way to do this let me know.
In my setup, I’d like to be able to monitor different mix busses and stems without a hardware monitor controller. I want to use my current interface inputs for external sources and be able to monitor my computer audio as well.
My kludgy solution is using Solo X-or but would be great if I can turn the monitor page in to a dedicated monitor controller without getting rid of my current interface for a MTRX let me know.
Thanks in Advance!
Dennis Cham
HIT PRODUCTIONS
music | sound design | post
www.hitproductions.net
Old 08-07-2019, 10:21 AM
EddieJones's Avatar
Default Re: Monitor Page in PT | Control
This works with EUCON enabled devices, MTRX, XMON, PT Master Fader, Nuendo, Pyramix etc. We are looking at expanding this in the future
Old 08-08-2019, 08:40 AM
Eddie, would you mind elaborating on how this works with PT Master Fader? Is this something that can be done without MTRX or X-Mon hardware?
Thanks!!
Scott Gatteño
Yessian
Old 08-08-2019, 09:25 AM
EddieJones's Avatar
You need to be on PT 18.7 or later.
Pro Tools lets you designate a Master Fader to act as a Monitor Path that can be controlled from EUCON control surfaces. Designation of a Master Fader as a EUCON Monitor path is stored in the Pro Tools session, letting it persist when a session is moved from a system with an S6 to one with a Dock, or similar.
To enable a Master Fader for EUCON Monitoring:
1 Ensure that Enable EUCON is selected in Setup > Peripherals > Ethernet Controllers.
2 Create a Master Fader track and assign it to any path being used for monitoring (this can be your main Monitor Path, or other).
3 Right-click the name of the Master Fader and select EUCON Monitor.
The Control Room/Monitor knob on your EUCON control surface controls that Master Fader track for monitoring.
For example, on the Dock with a Master Fader assigned to EUCON Monitor:
• Rotating the Monitor/Control Room knob raises and lowers the Master Fader level.
• Pressing the knob sets Master Fader level to –INF (effectively Muting or “cutting” the monitor level). Press again to return to the previous level.
Old 08-08-2019, 06:53 PM
Hello Eddie! Thanks for the reply.
I’ve tried using a Master Fader as a monitor out. But have more questions.
1) Can you assign multiple master faders to monitor multiple monitor sources and paths? And if so how do you assign this to to the Source buttons on the ProTools | Control monitor page?
2) Can you assign talkback without an MTRX or Xmon, but with any input on your interface like Source Talkback app from Source Elements?
3) Is there a way to monitor your computer audio as another source via the ProTools | Control monitor page?
I know the answer is buy a MTRX with a Dante option card or DMon. But for now, can I do this through my current Avid interface which I am perfectly happy with?
Thanks in advance!
Dennis Cham
HIT PRODUCTIONS
Old 08-08-2019, 07:19 PM
EddieJones's Avatar
I'm afraid the answers are no to these questions. Sorry
Old 08-10-2019, 06:50 AM
Thanks Eddie, time to save up for a MTRX.
Dennis Cham
HIT PRODUCTIONS
Old 08-10-2019, 05:42 PM
MrDibS MrDibS is offline
XMons are popping up cheap all over.
Mac Pro 2013 12 Core Trashcan, 64 gigs, OSX 10.14.6
PT HD Ultimate 2019.6, HDX with Focusrite Red 8pre, Dock + S3.
Old 08-13-2019, 09:00 AM
Wow! Thanks for the reply Eddie. I didn't see this until now. Much appreciated.
Scott Gatteño
Yessian
Old 08-14-2019, 12:21 PM
acacia acacia is offline
Hey Eddie,
I've got construction happening at the studio and had to pack up the S6. This is very helpful... Thank you! I just got the app and EUControl talking but am finding that when I am not actively on the DADman application and am working in Pro Tools (MTRX DADman is no longer focused) my monitor control goes away on the iPad. the page is still there but the app is no longer populated with my monitor profile. Is there a way to lock DADman similar to the S6 on the app so that the monitor page stays active?
Luke Rohwer
Acacia Recording & Production
www.acaciarecording.com
Luker[at]acaciarecording[dot]com
Studio 301-829-8088
2019.5 PT Control app Monitoring Page paulo m Pro Tools 2019 0 05-09-2019 05:40 PM
Pro Tools Control User on Page 1 juanjosalazar Pro Tools | Control 0 10-31-2018 08:40 PM
Dim Pot On Monitor Page. . . priorytools Pro Tools | S6 4 07-25-2018 02:42 PM
MC Control Tracks Page KeyplayerG Artist Series 0 08-12-2016 12:14 PM
Edit page jumps around with PT Control & MC Mix? Cheesehead Pro Tools | Control 3 12-22-2015 03:24 PM
