Old 09-11-2015, 06:32 PM
KGraham045 KGraham045 is offline
Default Sync I/O with PT 10HD Thunderbolt Native
I am trying to set up a PT10 HD thunderbolt native system with a Sync IO. But when I go to select Sync in periphrials it says a connection cannot be established. I have connected the 8 pin mini din cable from the Thunderbolt interface to the sync IO. I also made sure that there is a file in the ProTools utilities Sync folder. Can anyone help?
Old 09-11-2015, 06:59 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Default Re: Sync I/O with PT 10HD Thunderbolt Native
First, you need to be sure, or hope, that the serial cable is - i forget the actual term for it now - but bi-directional.... some only transmit one direction as I understand it
Next, I'd try to go into Digitest and see if there is a firmware update or something for it... make sure everything passes.
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 09-11-2015, 07:09 PM
The cable seems to be bi directional. As it has arrows going both ways on each sides.
I will check out digitest. I've never done digitest.
Old 09-11-2015, 07:15 PM
Right on. Cable should be cool then.
For sure run digitest. Have to do this after a restart if you have had PT open.
If I recall correctly, there is facility to update firmwares... I know there is for I/O's, but don't recall about Sync... been a long time since I had mine hooked up.... it just occupy's rack space now that I'm on 11 lol
Is protools otherwise cool? Your HDN setup is otherwise working?
OSX Sierra
Pro Tools HD 11.2.2
Extreme Server (x2)
Live:
Win 10, OSX Sierra
LV1, MRSG
Custom enclosure
Old 09-11-2015, 07:25 PM
Yeah, my PT10HD Native Thunderbolt works perfectly. I just got the sync IO and it powers up fine. Just wont seem to connect in the periphrials menu.
What is DigiTest exactly. I did a quick web search and it was for like PT 6. Same with the firmware for the Sync IO
Old 09-11-2015, 07:26 PM
Right on. for sure start with Digitest
OSX Sierra
Pro Tools HD 11.2.2
Extreme Server (x2)
Live:
Win 10, OSX Sierra
LV1, MRSG
Custom enclosure
Old 09-11-2015, 07:35 PM
Which version of Digitest would be appropriate for me to run? It all looks like it's from PT6
Old 09-12-2015, 07:08 AM
kurt's Avatar
kurt kurt is offline
The one you have in folder: Pro Tools Utilities
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Old 09-12-2015, 07:17 AM
Brandonx1 Brandonx1 is offline
A sync io will not work with an hd native card. You need a sync HD.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 09-12-2015, 08:40 AM
Does anyone know if this is true? I am using a Hd omni and a 192 io and they work fine together
WHAT OS for 10HD Native Adupr Pro Tools HDX & HD Native Systems (Mac) 7 02-07-2015 09:40 AM
HD native thunderbolt through Echo Express SE Thunderbolt Chassis hkj1 Pro Tools HDX & HD Native Systems (Mac) 1 11-06-2013 05:49 PM
Anybody switched to a Macbook Pro Thunderbolt Native from Mac Pro Native? petesteen Pro Tools HDX & HD Native Systems (Mac) 7 11-17-2012 03:21 PM
10HD nAtive + Universal Audio UAD-2 QUAD PCIe card bacchus40 Pro Tools 10 8 05-29-2012 05:41 PM
HD Native and Pro Tools 10HD zion Pro Tools HDX & HD Native Systems (Win) 8 11-04-2011 08:08 AM
