  #31
Old 09-17-2015, 10:40 AM
Skohi Skohi is offline
Default Re: "SystemId Entered does not match the SystemId on record for this Serial"
Hey Darryl thanks mate that link resolved it for me and I was able to complete the firmware update!
I cannot thank you all enough!! removed IE11 and removed 1 update named IE11 and all was fine :)
  #32
Old 10-10-2015, 03:08 PM
Jtnorwood Jtnorwood is offline
When I try to upgrade my Eleven Rack I get the same fail message:
SystemId (XXXX) Entered does not match the SystemId on record for this Serial Number (XXXX)
I'm running Windows 8.1 and although you can't uninstall IE11, you can turn it off in the programs list which I have done. This hasn't fixed the error however. My system is:
OS: Windows 8.1
Processor: Intel i7-4770K
RAM: 16GB
System Type: 64-bit OS, x64-based processor
Eleven Rack Firmware Version 1.0.3
Build 0.6.2.0
Any ideas?
  #33
Old 10-10-2015, 07:38 PM
Benoni's Avatar
Benoni Benoni is offline
OS: Windows 8.1
RAM: 16GB
Build 0.6.2.0
Any ideas?
Would you happen to have an old computer with XP on it laying around somewhere? If Win8 is the problems, then another PC is the solution. However, if the problem is the serial and id are wrong, then you need to contact Avid to get them reset.
  #34
Old 10-10-2015, 08:26 PM
I don't have anything with XP on it but I do have a windows 7 PC. Good lord if you need XP then WTF if going on?
Would Windows 7 offer a different result?
Thanks,
Jon
  #35
Old 10-10-2015, 09:17 PM
I used a PC with Windows 7 and uninstalled IE on it. I got the same error:
What's my next move? Also is there a phone number I can call? The support page leads me around in circles. I'm starting to regret this purchase heh.
Jon
  #36
Old 10-10-2015, 09:49 PM
Benoni's Avatar
Jon
Don't regret it, you'll get setup. The protection scheme is just a nightmare with the ERXP. You will probably need your numbers reset since you already typed them in on one computer. The Windows 7 machine should work if you can get rid of IE9 and above.
  #37
Old 10-11-2015, 07:37 AM
DigiTechSupt's Avatar
Jon
Hi Jon,
Let me create a case for your concern and will get one of our technical support representative call you back to help you with your concern. And just for a reference, our support line number is 650-237-1700.
Best Regards,
YD
Avid Audio Tech Support
Support FAQ
  #38
Old 10-11-2015, 10:01 AM
Originally Posted by DigiTechSupt View Post
Hi Jon,
Best Regards,
YD
Thanks alot, everyone here has been a big help.
Jon
  #39
Old 10-13-2015, 09:17 AM
This is resolved. The serial number was wrong and I used a Win 8.1 machine that further goofed up the process so yay.
Thanks for the help.
  #40
Old 11-06-2015, 07:02 AM
Andy Ewings Andy Ewings is offline
Hi Guys,
I`m new too and have exactly the same problem, I`m running windows 10 on one system and now have an 8 system sitting here which still tells me the ID/serials don`t match.
Contacted support" Eleven expansion pack [Case : 02820953]" and the code they gave me said it had already been used.
Think I need to lay down before it all goes out the window!
Expansion Pack - SystemID? jimst57 Eleven Rack 6 03-22-2011 01:12 PM
Switching a HD from "transfer only" to "record mode" BretFarewell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-16-2010 12:49 PM
"Some Automation Parameters in the clipboard do not match the paste destination" adamjay Post - Surround - Video 4 01-07-2010 07:22 PM
Importing track removes "Match Criteria" info? reichman Post - Surround - Video 1 08-31-2009 10:54 PM
"Could not complete the open the session command because Magic ID does not match." willyrmc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-10-2003 01:47 PM
