Old 10-08-2012, 04:35 AM
Snafu Snafu is offline
Default Signal from CDs and Phono Preamps too high for Mbox 3?
Hi guys,
after 2-3 years of blissful PT8 times, I'm crawling bach here pleading for help. Is there anything I can do to record into Pro Tools (8, Mbox 3) when the signal coming in from the phono preamp, or any CD, is far too loud even with the input gain at its lowest? Is there a setting I'm missing somewhere? Surely it can't be possible that the Mbox is incompatible with pre amps (or cds!!!).
Thanks in advance, and fingers crossed!!
Old 10-08-2012, 06:18 AM
Default Re: Signal from CDs and Phono Preamps too high for Mbox 3?
Just discovered Pads. Problem sorted (unless someone tells me Pads reduce sound quality?) DOesn't seem to be the case though:)
Old 10-08-2012, 07:41 AM
nst7 nst7 is offline
For CD's, it would be better quality to just import the Wav file into Protools.
If you must record traditionally, then use the digital Spidf jacks.
CD players with digital outs are expensive, but there is a very cheap alternative: use a consumer DVD player (get a cheap one from Walmart). They all play CD's and they all have digital outs.
Old 10-08-2012, 08:36 AM
Well said^^^ I use Wavelab to rip audio from CD's, but even iTunes can do it if you go into the preferences and tell it to import as wave(without any compression).
High End Preamps (Neve 1272 Pair, Manley Slam!, Tube Tech MP 1A) Eduardo Apolonia Buy & Sell 2 03-05-2014 08:56 AM
Monitoring the Phono Input on an MBox 2 Pro Alan Brownstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-04-2011 12:24 PM
mbox 2 pro , phono input hotmass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-18-2007 05:45 PM
mbox and phono level tromba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-07-2004 08:32 AM
Preamps / patchbays / signal integrity phaseout 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-10-2002 02:20 PM
