Old 09-11-2012, 09:15 AM
raniel raniel is offline
Default No sound on master fader
I made a new project in pro tools LE and startet to record a new song and everything went fine uintil i made master fader track, now when i restarted PT the project gives no sound through the master fader. I can see that there is sound on the other faders/tracks put non coming out to the master fader.
Any tips on what the prob might be?
Old 09-11-2012, 10:18 AM
Default Re: No sound on master fader
Check the output on the master track. Odds are its NOT the same as the rest of your tracks
Old 09-11-2012, 10:30 AM
it is the same.
if it was not, it would not have worked the first time.
it stop reciveing signal after PT restart...
Old 09-11-2012, 12:35 PM
RegenerationMix RegenerationMix is offline
Default Re: No sound frrom master fader
are the other tracks set to output to your main 1-2? What is the master fader set to? A photo of the mix window would help so we could see your routing.
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
Old 09-11-2012, 05:04 PM
Maybe the audio engine has changed? Check that under Setup>Hardware
Old 09-11-2012, 09:54 PM
Its set to 1-2 as the rest of the faders.
Il post a photo later today.
Old 09-12-2012, 01:53 AM
Stig Eliassen's Avatar
Originally Posted by raniel View Post
it is the same.
You always have a master fader in your session. Even if you didn't create one, it's there - behind the scenes. This means that you can work in PT all day long without creating a master fader. It's already there, and set to unity gain.
Old 09-12-2012, 10:31 AM
how do i post a photo? :\
Old 09-12-2012, 10:41 AM
http://duc.avid.com/faq.php?s=&do=se...l&titlesonly=0
Old 09-12-2012, 10:49 AM
and?
Is there any sound degradation when turning down a master fader? led5150 Tips & Tricks 38 07-30-2013 07:50 AM
issue with sound quality after ive added the master fader Duckett Pro Tools 9 10 04-24-2013 04:36 AM
i/o on master fader produces no sound using mbox pro and pro tools 10 desertguitar macOS 2 11-11-2012 03:30 PM
no sound on master fader KirinBenjamin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2002 09:50 AM
Why does Pt master fader sound best @ -12dB? NATEMYST Pro Tools TDM Systems (Mac) 6 06-04-2002 12:47 AM
