Old 04-26-2002, 06:50 AM
Garry Taylor Garry Taylor is offline
Default Limiting and compression.
Hi guys (and gals)
Forgive the newbie question (my first post on this list).
I'm recording vocals, but when I put in a limiter or compressor on the channel I'm recording on, it seems that it doesn't effect the level on its way to the disk, only monitoring or coming back from disk.
Is this usual, and if so how do you limit the signal on the way to the disk, so it doesn't clip.
TIA.
Garry
Garry Taylor
Sound Designer/Musician
Sony Computer Entertainment Europe
Old 04-26-2002, 07:07 AM
Default Re: Limiting and compression.
Sorry, forgot to say I'm coming in through a Control24 console.
Garry Taylor
Old 04-26-2002, 07:16 AM
stoneinapond stoneinapond is offline
Garry,
An insert does not affect how a track is recorded. If you want to record with processing (and please be sure that this is what you want to do,) then you should bring your signal into ProTools on an auxilliary track, insert the effect there, and then bus the output of the aux to the inputs of the track you wish to record to.
You will then be recording a processed input.
Hope this helps,
Yorik
Old 04-26-2002, 07:28 AM
AE AE is offline
There are two answers for this question:
Most important, if you're trying to limit during recording to avoid clipping, then you need a limiter prior to the A/D converter; otherwise, it's too late. So you really need an analog limiter in your chain. If you have a converter with a "soft clip" capability, that might do the trick. Other posts on the DUC have stated reservations about the 192k interface's soft clip limiting, if that's the A/D you're using.
In general, if you want to track plug-in signal processing to disk, create an aux in track for you signal and use that track for plug-ins. Send the output of the aux track to a bus and choose the same bus for the input to your audio track.
Old 04-26-2002, 07:32 AM
Thanks people.
I thought using and aux track and buss would work, I wondered if there was any other way.
OK. Now I know.
Thanks again.
Garry
Garry Taylor
Stem and mix bus compression/limiting for picture? efisch Post - Surround - Video 8 04-30-2009 07:11 AM
Normalizing vs Compression or Limiting barismanco123 Tips & Tricks 17 01-23-2009 11:08 AM
Compression/limiting after encoding hef Post - Surround - Video 4 05-14-2008 08:03 AM
6.1 Compression & Limiting derF Pro Tools TDM Systems (Mac) 1 05-20-2004 12:34 PM
Compression and Limiting - External DSP choctop Digidesign Hardware & Software 1 03-28-2001 01:07 PM
