Old 12-28-2007, 04:36 AM
midi sordino midi sordino is offline
Default Problem with Pro Tools as Rewire Host for Reason 4
Hi there,
I've been using Pro Tools as a ReWire host for Reason 3 with no problems.
Now that I've upgraded to Reason 4 I've been getting the message 'Reason Engine Not Responding. Please check ReWire Host Application' when I launch SOME PT sessions with Reason inserted on an instrument channel.
I can't figure out the problem as it will launch on some sessions but not others. On sessions where it won't launch, I de-select Reason and re-insert it on the channel and I'm told that the Reason engine is already in use.
I've used the tech support utility to trash all prefs and databases and the problem is stil there.
I've reduced the instances of Reason in a session to one but still no luck in determining the, ehem, reason for all this. It will work in one session but not another with no apparent difference.
In know Prop Heads have admitted problems with PowerPC compatibility but not this kind of problem...
Anyone any bright ideas?
Thanks,
Midi.
Dual 2.7Ghz PowerPC G5/ Mac OS 10.4.9/ 002 Rack / PT LE 7.3.1/ Reason 4
Old 12-28-2007, 05:57 AM
Phil Ogden Phil Ogden is offline
Default Re: Problem with Pro Tools as Rewire Host for Reason 4
Have you got the latest Rewire Drivers (1.7)? Worth a try if not.
http://www.myspace.com/philogg
Old 12-28-2007, 03:56 PM
Default Re: Problem with Pro Tools as ReWire Host for Reason 4
Cheers.
ReWire 1.7 is there all right.
I've just re-installed Reason and problem has gone with one session but is still there in another. When I de-insert Reason in a problematic session and re-insert it I'm told the Reason engine is in use by another program.
Not sure what is causing this..
Does Pro Tools SE work as a rewire host? monkeysticker Pro Tools SE and Essential (Win) 1 08-16-2016 06:28 AM
pro tools rewire reason 5 problem deziarlleh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-04-2011 06:08 AM
Reason 5 in Pro tools LE 8.0.3 rewire problem. LizS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 10-28-2010 04:18 PM
instaled pro tools 7.3 & reason 3, REWIRE PROBLEM! tomward Pro Tools M-Powered (Mac) 1 03-04-2007 05:31 PM
reason - rewire - pro tools only 2 tracks problem Tex Tiles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-11-2003 02:25 PM
