Old 01-08-2007, 10:17 PM
jhermais jhermais is offline
Default Midi Signal In - Will not record
I will post the question again:
Setup:
Protools LE 6.9 rack Master
Windows xp home
Vairo Desktop computer
Wammi Box (as interface) neutral
Triton workstation Slave
Phantom Keyboard Slave
I see the signal on the front of the unit, and the outputs are lite up. On my workspace, the vu meter is showing signal (solid, not jumping around)
I Select my input device=Wami Box
I select my output device=digidesign port 2
The keyboard is receiveing midi signal and is playing and obeying commands. I record enable the track, click record button on transport, hit play, and keyboard plays. The cursor moves across the track, but nothing is being recorded. Sometimes when I exit out that session, Protools will say that I have recorded midi data, but I can't see it.
I searched for the OMF file, but don't know what I am setting up. Any suggestions
Old 01-09-2007, 08:40 AM
JMS40 JMS40 is offline
Default Re: Midi Signal In - Will not record
Sounds to me like you've got Midi connections made but no audio connections from your synth(s).
Midi data contains no audio.
In order to hear/record playback from your external synth(s), audio outputs must be routed to Pro Tools as well.
No signal can't record theorganist macOS 1 12-02-2012 03:02 AM
No audio signal or midi signal after pro tools 8.04 upgrade allgenres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-01-2010 08:58 AM
Trying to Record Midi ... no signal! TDub MIDI 6 04-22-2006 07:06 PM
No Midi signal, no audio signal, buzzing monitors! 1tonstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-26-2004 07:01 AM
Not getting signal to record wagonburner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-20-2004 01:26 PM
