weird problem with core card
Dear Gentleman and colleagues
I came to the solution of a problem that is been freaking me the f..ck out lately since I upgraded to PT 10.2 I started having these errors like 1 PROTOOLS DOES NOT HAVE ENOUGH VOICES TO ALLOCATE. 2 The computer would restart by itself 3 I would hit play and no sound would come out of the session After a million trials and errors, aside from removing all the cards from the magma chasis, the host card, re installing OS, protools, plugins, checking for latest versions etc. I really dont know how I came to this soultion but it works, and I was wondering if it tells you anything What I do now is start protools and before loading a session, I open the USAGE WINDOW and option click on the chips of the core card, to allocate them all, stoping Protools from loading any plugin on those chips and presto. IT F...ING WORKED Im not sure if there is something wrong with the code, or the cosmos wanted that the same afternoon I installed 10.2 my core card went bananas. but now it works steady without a single problem Does anyone has any idea what the hell is happening? Thanks in advance
I used to be insecure...now I'm not really sure |
Re: weird problem with core card
Why are you still using v10.2? v10.3.4 is available.
Have you ran DigiTest on your cards?
Hello
First, thanks a lot for answering. Yes I am already on the very last version. if you read my message it says SINCE. I upgraded to that version. And yes I run the digitest. nothing wrong Again thanks for your answer
What happens when you put the core card in the CPU?
I havent noticed, I will look and tell you
However, I can tell you that if I dont allocate the chips, the session will die
Let's see if the chassis is contributing to the problem.
This system, has remained the same since 2003. Same chassis. Changed the motherboard when changed computer ( pci-e)
More important. the system worked flawless last year with PT 9 PT 10 and 10.1 when 10.2 showed up then all hell broke loose Im suspecting a bad core card maybe?
If you have the same problem with the card in the CPU, then yes, plus you eliminate the chassis as a contributing factor.
I have no way to eliminate the chassis. My cards are pci, my computer pci e
but thats besides the point.
PT HD1 (core card PCI) x PTHD1(Accel core card PCIE) | Alécio Costa | Pro Tools TDM Systems (Mac) | 6 | 05-02-2017 06:52 AM |
Hackintosh PCI-X Core Card problem | Blake Henderson | macOS | 8 | 06-29-2012 02:07 PM |
Need opinions: Do I have Core card problem or computer problem? | johnnyv | Pro Tools TDM Systems (Mac) | 2 | 08-11-2010 06:36 PM |
Huge Digidesign PCI Express Core HD card BSOD problem | Gorazd Koncar | Pro Tools TDM Systems (Mac) | 3 | 03-10-2009 07:22 PM |
G4 Core Card/RAM Hardware Problem | Wyn | Pro Tools TDM Systems (Mac) | 2 | 12-14-2003 09:52 PM |
