002R drivers don't work for 9.0.3?
This thread started over on the PT9 OSX forum, but someone suggested I try over here because of my lowly 002R.
I could really use some help. I was having some problems getting MIDI to work on my 002R - I'm not the first, I know... In trying to solve the problem, I upgraded to 10.6.7 and PT 9.0.3. And I didn't save a disk image of my working config. Duh. The 002R MIDI problem never got solved (do they just put the MIDI jacks on and not wire them up?), I dug up an old Midisport and that worked fine. Then, however, PT wouldn't recognize my 002R. It shows up in AMS fine. So, I did all the usual things, trashed prefs, etc. etc. And, of course, reinstalled the PT9 002R drivers, and now PT won't even open. And when I look on the driver updates page, the 002R drivers are qualified to... 9.0.2. Anyway, here's the error message: Process: Pro Tools [225] Path: /Applications/Digidesign/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: ??? (???) Code Type: X86 (Native) Parent Process: launchd [156] Date/Time: 2011-06-01 18:52:58.953 +0200 OS Version: Mac OS X 10.6.7 (10J869) Report Version: 6 Interval Since Last Report: 34648 sec Crashes Since Last Report: 2 Per-App Crashes Since Last Report: 2 Anonymous UUID: 12D8E953-1DC9-4329-AB3F-49E5D210DB07 Exception Type: EXC_BREAKPOINT (SIGTRAP) Exception Codes: 0x0000000000000002, 0x0000000000000000 Crashed Thread: 0 Dyld Error Message: Library not loaded: @executable_path/../Frameworks/CFnd.framework/Versions/A/CFnd Referenced from: /Applications/Digidesign/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools Reason: Incompatible library version: Pro Tools requires version 9.0.3 or later, but CFnd provides version 9.0.0 Binary Images: 0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <1C06ECD9-A2D7-BB10-AF50-0F2B598A7DEC> /usr/lib/dyld Model: MacBookPro4,1, BootROM MBP41.00C1.B03, 2 processors, Intel Core 2 Duo, 2.5 GHz, 4 GB, SMC 1.27f3 Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 512 MB Memory Module: global_name AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8C), Broadcom BCM43xx 1.0 (5.10.131.36.9) Bluetooth: Version 2.4.0f1, 2 service, 19 devices, 1 incoming serial ports Network Service: Ethernet, Ethernet, en0 PCI Card: sppci_expresscard_name, sppci_pci2pcibridge, PCI Slot 3 PCI Card: sppci_expresscard_name, sppci_ieee1394openhci, PCI Slot 3@11,0,0 Serial ATA Device: Hitachi HTS542525K9SA00, 232.89 GB Parallel ATA Device: MAT[bleep][bleep][bleep][bleep]ADVD-R UJ-867 USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd400000 USB Device: Composite Device, 0x0763 (M-Audio), 0x1021, 0x1d100000 USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0230, 0x5d200000 USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x5d100000 USB Device: Hub, 0x04cc (NXP Semiconductors), 0x1122, 0x1a200000 USB Device: iLok, 0x088e, 0x5036, 0x1a220000 USB Device: USB Receiver, 0x046d (Logitech Inc.), 0xc505, 0x1a210000 USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x1a100000 USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x820f, 0x1a110000 FireWire Device: Pro Z RAID, FirewireDirect, Up to 800 Mb/sec FireWire Device: Digi 002Rack, Digidesign, Up to 400 Mb/sec FireWire Device: Raptor RT, FirewireDirect, Up to 800 Mb/sec
System 1: 2023 Mac Studio 64Gb RAM, OS 13.6, PT Native 2023.12, Metric Halo ULN-8, LIO System 2: 2021 M1 Mini 16Gb, OS 13.6, Native 2023.9, MH ULN-8 4d http://www.mylescochran.com |
Re: 002R drivers don't work for 9.0.3?
OK, solved, thanks to this post, although it's good to mention that, once you've re-selected the 002 as the playback device, you need to go back to the input/output tabs and select the defaults to repopulate the grid with the ins and outs of the 002/R. I guess this is the result of not having the drivers built-in like in LE, but it never happened with 9.0.2, even when switching around using the 002R for iTunes playback.
Are the existing 002 drivers actually compatible with 9.0.3?
low latency monitoring doesn't work on 002r latest drivers | jntracks | Windows | 26 | 03-31-2011 11:23 PM |
Micro and 002R Drivers? | jpoprock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-20-2008 10:17 AM |
Buying a used 002r without drivers??? | Matt Reisinger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-26-2006 09:31 AM |
DRIVERS DIGI 002R | 120359 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-23-2004 02:19 AM |
I'm installing 002r drivers every day | 40mutesheep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-26-2003 10:04 PM |
