Go Back   Avid Pro Audio Community > Other Products > The Drum Room
  #21
Old 06-15-2010, 11:55 PM
BradLyons BradLyons is offline
Default Re: Overhead mics?
Earthworks microphones are NOT over-priced---they are premium microphones, IMHO. I've been using the TC30K's for several years now in the studio due to their accuracy, zero issues with phase, and my cymbals sound like my cymbals. Other microphones can produce great results too---that's not to say that Earthworks are the only answer---but nothing performs like them. With that said, again they aren't the only answer. I can't speak for KeyBeets and his situation---only my own.
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
  #22
Old 06-16-2010, 06:39 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
I mostly agree with Thee Mad Brad; I didn't say they were over-priced because I think they're wonderful as well as priced well; but for the work that I do, they were "overkill" & I only say that for lack of a better description (I thought I said all this in my original post)..
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
  #23
Old 07-31-2010, 08:41 AM
paul_g paul_g is offline
Octava's are great! I use them at my home studio and work/sound wonderful.
When I'm in the actual studio (with a mic closet to die for, that I didn't buy...)
My choices are:
DPA 4011's
Schoeps CM6's
Or Neumann KM 184's
All three brands are amazing, out of my price range, and do a wonderful job.
I prefer the DPA's for overheads. But they're all very close. The Schoeps are nice because you can change the polar pattern from cardioid to omni. For overheads, always use Cardioid.
But I don't stop there..... Also, when in the studio, in the live room after the kit is all mic'd I also put up two Earthworks QTC40's which are very sweet - high end, omni's. Depends on the song or genre if they'll get used in the mix... but it's always nice to have. And never forget your "crazy mic" - a cheap affective condenser that you stick somewhere... anywhere... some bizarre place in the room just to see what it picks up. This is a great trick because you can take that track and do insane things, i.e. low fi/smashing with compression -etc.. Have fun with it, that's why I call it the "crazy mic". If you don't like it in the mix, just mute it or make in hidden/inactive.
There are several mic'ing technics for overheads
1. Spaced Pair - measure the overhead left equal distance from the right by measuring from the center of the snare, otherwise, you'll get too much high hat and snare pulling to the left.
2. Coincidental pair (x/y) from the center of the kit. A lot of people like this because it's simple and almost eliminates any chance of phase. But the stereo spread isn't as great.
3. ORTF - kind of like an x/y but the mic capsules are 110 degrees from each other... Similar to an x/y, they almost have zero phase and create a better stereo spread than Coincidental Pair.
For mix - just pan them to taste - I never go 100/100, I try to keep them 60/60 or somewhere around there. Usual eq - sparkle on top - maybe some low cut, compress and maybe bus them to a reverb or whatever.
Remember, the overheads make up about 80% of the drum kit. Everything else is to fill... I've seen mixes where almost the whole thing was done w/ three mics... couple of overheads and one in the kick or even one somewhere else -
For more mic'ing techniques, Glynn Johns - famous for all the Zep stuff is a good one to look into, but you'll need large diaphragm condensers.
It's all on google - tons of material out there! Just have to look for it and take your time experimenting. Nothing saying you can't have a drummer come in for a session where there is no other objective other than trying different techniques and mic's.
Good luck!
2.4 ghz Intel Core 2 Duo iMac
OS: 10.7.5 (Snow Leopard)
4gb (667 MHz DDR2 SDRAM)
LaCie Audio Drive - FW800
DigiDesign 003 Factory PT10.2.0
PreSonus DigiMax FS
  #24
Old 08-18-2010, 03:36 PM
barters81 barters81 is offline
Great advice Paul.
Due to using ribbons as overheads in the main these days I've been doing a "trick" (its a trick to me, but probably not to others) to create the sparkle, yet in a smooth way.
I've been sending both tracks to a AUX track which has eq and compression. The eq strips all the bottom end, and boosts the highs. The compression is quite heavy with a fast attack time and a slow release. I then blend the AUX track to taste. The idea is to bring out the highs, but to compress this so the crashes etc don't explode out of the mix, but shimmer and glean after a hit. The original overhead track provides the guts of the sound.
I've ben experimenting a lot with mic placements recently. I pretty much use the spaced pair method as I really like the wide stereo signal. However, I'm finding that by measuring I will keep my snare in phase, but one or two toms may be out of phase. And....using ribbons, the overheads catch a lot of toms etc.
I also then use a condensor on the highhat. I never used to mic the highat until I started using ribbons for OH's. My theory here is the highats really sizzle through even at a low volume.
- Macbook Pro 2.5Ghz, 4gb RAM, 320Gb HD @ 7200RPM
- 2 x Profire 2626
- PT8.0.1 M-powered
- Yamaha HS80M
- Axiom Pro 49
- 500GB Sarotech Hardbox external HDD plugged through express card, FW800
- Waves Gold bundle, L3-16, Eddie Kramer
- 2 x Coles 4038, Royer 121, 2 x Shinybox MXL, 4 x SM57, 3 x SM58, AKG D112, SM81, Shure 16A, sE 2000, 3 x Audix D2
  #25
Old 11-12-2010, 09:13 PM
MarkJordan MarkJordan is offline
I have been using the Rode NT-3's recently for overheads and they sound really good provided the placement is done properly. I usually breakup the drum kit overhead miking into three sections. Left overhead is placed near the over the hats looking in between the snare and toms, so this covers snare, high tom, hats and cymbal 1, a Center overhead placed pointing at the snare covers mid tom snare a lil of the kick and cymbals 2 and splashes, a Right overhead covers remaining cymbals and floor tom. These mics are then panned Left center and RIght to give an amazing stereo image.. a little fiddling around to be done to reduce phasing, but otherwise it creates a wide stereo image where toms automatically pan frm left to right snare and kicks are in the center, hats and cymbals range frm left to right again..i've also tried these mics in simple spaced pair and xy which did not give that much of stereo seperation..would love to try out neumann 170R's or AKG C414's for xy or ab...
  #26
Old 11-15-2010, 10:38 AM
Hotcrazyfruit Hotcrazyfruit is offline
AT 4041's. Very bright. 500 for a pair brand new.
Core i7 920 OC'ed @ 4.0 GHz (200 X 20)
12 GB Patriot Viper Extreme
Asus P6T
OCZ Agility 64 GB SSD
Hitachi 1TB 32 MB HDD
WD Caviar Black 500GB
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Fender Super Champ XD
Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet
  #27
Old 09-06-2011, 03:59 PM
MrTinkle MrTinkle is offline
I've only just skim read through this so you'll have to forgive me If this has already been asked...
Has any one had chance to play with some SE SE4 microphones? If so, what's your thoughts about them?
  #28
Old 09-07-2011, 01:46 AM
ejwells's Avatar
ejwells ejwells is offline
I currently use a set of Josephson C42's for overheads.
Love them to death!
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
bfd ultra, no overhead mics?? guitardom Virtual Instruments 7 06-08-2007 01:01 PM
Overhead Mics.... rock15478 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 09-20-2005 03:31 PM
so it all comes down to.....overhead mics nightshadecrisis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-23-2003 08:50 AM
What are the best overhead mics??? Big Tyme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 11-18-2002 03:35 PM
Drum Overhead Mics MikeD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-11-2001 12:36 AM
