Neyrinck v-control-pro with procontrol
Anybody using neyrincks v-control-pro with their digidesign procontrol on pro tools 11, 12 or 2018 and if so how are you liking it? Anything you don't like about how it works?
Re: Neyrinck v-control-pro with procontrol
See my post in the Control|24 and ProControl with Pro Tools 11? thread: http://duc.avid.com/showpost.php?p=2...postcount=2190
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
I'm using it with 2018.7 so far so good. I hope future rev will allow access to the matrix and plug ins. The transport seems a touch slow . i was using it with 10HD for tracking and the punch in/out was better. But now at least in can use the pro control :)
Plug-in editing was originally implemented in the HUI protocol, so this should be possible at some point in time.
Access to the matrix however will never be possible because this was not originally implemented in the HUI protocol.
Thanks Marc, i'm looking forward to the plug in support.
Are you also experiencing a slight delay at punch in or could it be i didn't set everything up properly (i.e. firmware on pro control ?) |
Also take into consideration that the HUI protocol is a MIDI protocol and not the original Ethernet protocol for ProControl. So there is some translation going on between low-level Ethernet commando's to V-Control Pro to MIDI to Pro Tools and back. So this could cause some slight delay, however I find using ProControl with V-Control Pro and Pro Tools very snappy. I only have experiences with my 48 ch ProControl, they all have firmware COMv1.37 FDRv1.37. So if you are running an older firmware version in theory it could have something to do with the slight delay you are experiencing, but I doubt that really.
Pro Tools | Control vs. Neyrinck V-control pro | dr_daw | Pro Tools 12 | 35 | 08-17-2015 03:38 AM |
Neyrinck V-Control Pro issues | Southsidemusic | Pro Tools 10 | 2 | 10-01-2013 12:20 PM |
Neyrinck V Control causes PT11 to crash | txshonk | Pro Tools 11 | 9 | 09-15-2013 08:25 PM |
Should Neyrinck Pro Control work | Southsidemusic | Pro Tools 11 | 3 | 06-21-2013 07:29 PM |
Neyrinck V-Control advice | Jon_Atkinson | Pro Tools 10 | 3 | 08-28-2012 03:42 AM |
