#31
Re: EUCON 3.7 crashes immediately!!!!!
Please can you tell me the version number in the EUCOn prefs panel ?
#32
You can manually delete the offending files after uninstalling:
You can do this in the Finder by going to the Go menu and choosing Go To Folder… and type in /usr/local/lib You should not see libEuCon2.dylib or libEuConDLL.dylib If you do, delete them, then reinstall. |
#33
Sorry I had to revert back to 3.6.1 (to make at least the Dock working properly ) . my control panel now says 4.0.1x12414248 (but remember I went back to 3.6.1)
#34
OK. It should say 4.0.3.134 if 3.7 is installed correctly
#35
Tried uninstalling again and re-installing.. and deleting ALL the files (System files included) with the word eucon or euphonix, but control panel still says 4.0.1.x12 (even removing the control panel app)
#36
You can manually delete the offending files after uninstalling: You can do this in the Finder by going to the 'Go' Menu and choosing 'Go To Folder'… and type in: /usr/local/lib You should not see libEuCon2.dylib or libEuConDLL.dylib If you do see any of these files, delete them, then reinstall 3.7. |
#37
Still failing
#38
Can the people who this is not working for, make sure EUCON and PT are not running before uninstalling.
We have found the issue so are working on getting it up but need to build and test before posting. I'll post a link here as well as get it into users accounts. |
#39
Heres a screenshot of the files that needed to be removed after uninstalling for those still with issues. You can check if you have the right location as they will definitely be there in EuControl is installed.
#40
They are definitely not running.
Still failing OS x Sierra 10.12.6 |
EuControl 3.7 crashes immediately with PT | moranibus | Avid S1, S3, Dock and Control App | 11 | 10-19-2017 08:52 AM |
Pro Tools crashes immediately | Rich Crescenti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-21-2010 03:44 PM |
PT8 M-Powered Crashes Immediately | chrisconover | Pro Tools M-Powered (Mac) | 10 | 05-31-2009 10:19 PM |
LE 6.4 crashes immediately with 002R | j20056 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-27-2005 06:37 AM |
Mac G4 Crashes Immediately...I'm really new to this | luapfitz | Pro Tools TDM Systems (Mac) | 2 | 09-04-2000 05:40 AM |
