Old 10-18-2017, 06:54 AM
antonis's Avatar
antonis antonis is offline
Default Clear Edit Selection shortcut
Sorry all if this is a daft question:
Is there a shortcut that clears both the edit/ clip selection on the edit timeline and clears it from the clip list?
I am trying to avoid going for the mouse everytime I want to clear an edit selection and go back to the selector tool.
For the time-being I am pressing tab (to clear the edit selection) and cmd+shift+D (to clear it from the clip list)
Old 10-18-2017, 12:26 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Clear Edit Selection shortcut
If the whole clip is selected, command+shift+b will clear it from the clip list, which will in turn clear it from your edit window.
If not, press b first, to put a break in the clips, then you can clear it.
Unless I'm mistaken, command+shift+d just clears your search result in the clip list, after doing a command+shift+f to find certain clips? I'm not in front of my Pro Tools at the moment...
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 10-18-2017, 02:07 PM
antonis's Avatar
Thanls for the input Ryan
No, cmd+shift+b clears the clip. I want to clear the edit selection in both the timeline and the clip list in one go.
Old 10-18-2017, 02:37 PM
Ryan Young's Avatar
Again, I’m not in front of my pro tools system right now but maybe I’m confused about what you’re trying to do. Give the above a try and you’ll see it clear from your timeline as well, won’t it? I do this command almost daily to clear guide tracks out of adr sessions.
-Ryan Young
Additional Systems
Old 10-18-2017, 04:26 PM
minister's Avatar
minister minister is offline
On a Mac, just hit the CLEAR button
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 10-18-2017, 04:41 PM
Ryan Young's Avatar
There might be a setting that has to be checked in order for my method to work
Excuse the computer lag, the screen capture made everything lag but you'll get the idea.
-Ryan Young
Additional Systems
Old 10-18-2017, 11:56 PM
Stig Eliassen's Avatar
Up/Down arrow to clear edit selection, then P or ; to switch track also works.
Old 10-19-2017, 01:27 AM
antonis's Avatar
In the Digidesign logickeyboard, the Clear button acts exactly like cmb+shift+b!
Yes, the down arrow is a good option! Better than tab. It does not clear the previous selection on the clip list though...
Old 10-19-2017, 04:51 AM
True, and that's why I toggle which track the cursor is "parked" at with P or ;.
Old 10-19-2017, 09:22 AM
Inglesworth Inglesworth is offline
I was going to suggest the up or down arrows to move the edit selection to either the in or out point of the selection.
But I don't believe that this actually clears any selection in the clips list, FYI.
HTML code is On
Edit selection follows Clip list selection [solved] HDXSound Pro Tools 12 2 09-26-2017 03:02 AM
Any shortcut to audition selection in edit window? Tom M macOS 3 07-19-2013 10:45 PM
Link edit and time selection shortcut? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-27-2009 01:19 PM
Shortcut for moving Edit Selection Start to End? kid pro Pro Tools TDM Systems (Mac) 1 02-04-2003 11:24 AM
