Pro Tools 11 & 10 don't see my iLok 2
I use Pro Tools once in a while. Today my ProTools 11 install would not launch because it can not find my iLok. I have a Pro Tools license on the iLok as well as many other licenses. All my other applications see the iLok and the various iLok licenses are working normally. My DAW is offline with no internet connection. I run a Win 7 pro x64 OS and haven't had any updates since commissioning the DAW. I have been using the iLok License Manager v3.0.1.1373 as it seems to be the most recent version that will run on my Win7 install. Any suggestions for getting Pro Tools to launch? Thank you. |
Re: Pro Tools 11 & 10 don't see my iLok 2
I don't know if that is the most recent ILM s/w but the latest versions are supposed to run on Win7 32 & 64 bit. There was a brouhaha a couple of weeks back about iLok not sending out a warning email about having to update because some s/w wouldn't run/activate.
Hi Jack,
Thanks for the reply. Early this year the updates starting requiring that Win 7 have certain OS updates applied, so I have been using the last iLok License Manager that did not require that I update my offline DAW with a Windows update. I had heard something about a recent update to iLM late in the summer that worked with Win7 but I didn't understand if that meant that it worked without the previously required updates or if the discussion was about Win7 capability versus no Win7 capability at all. The thing that has me most curious is the concern that my Pro Tools license may have had some sort of timing feature. It worked great, and then with zero changes to the DAW it stopped working. All my other DAW software sees the iLok and the licensing and the system lets me use my iLok licensed efx. The problem seems exclusive to Pro Tools. |
I don't know what updates for Windows 7 you are referring to (got a link to that exact info?) , but you are dead in the water,... so if you can find that info in cold hard facts on iLok.com's support site then install those updates. There is nothing in current ILM release notes that I can see.
Then uninstall and reinstall the very latest ILM and Trash Pro Tools prefs. (both are pretty standard troubleshooting step you should have gotten to yourself). Still not working? What *exact* Pro Tools error message are you getting? My next step would likely be reinstall Pro Tools. |
FWIW, This is one of numerous articles about the iLM Win7 updates issue:
http://avid.force.com/pkb/articles/e...rror-Windows-7 "Beginning with Version 3.1.3 of License Support (which includes the iLok License Manager application and the drivers and services required to authorize iLok-protected software) Windows 7 must have specific updates..." The DAW is offline so installing a huge Windows update is not something I am particularly interested in doing. ProTools has been working fine without any updates. I don't need an updated iLok license manager for any of my other iLok licensed software. They work fine. Pro Tools simply flashes a dialog that says it needs an updated iLok manager and that it can not find my iLok, which the iLM can see and which all my other software sees. That's why I wondering if there was some sort of time bomb in my ProTools install. Nothing has changed regarding the ProTools install in several years. I don't update or add software very often. |
The error is telling you what you need to do, and you don’t want to do it. I am not sure what else you expect other users here to do for you.
Sent from my iPhone using Tapatalk |
Hi Jack,
I have the final versions of PT 10 and PT 11 installed. I can't launch them so it isn't so easy to look at the "about" and see what version number they are. The iLM update that you are referring to is newer than the iLM version I am running. The iLM version I am running did not hose my system the way the notorious early summer update did. The iLM version and iLok I am running works perfectly with my other software. I have been working since 6:00 a.m. with another application and everything is fine. I just need to figure out how to get Pro Tools working with everything as it was before yesterday. Thank you. |
Pro Tools says linked with iLok account, but iLok doesn't have my Licence! HELP! | nathanhyatt956 | Licensing & Accounts | 0 | 05-13-2017 11:51 AM |
FS: Pro tools HD9 transferable to Ilok account €250 (paypal and ilok fees included) | Mikek33 | Buy & Sell | 1 | 12-02-2014 04:39 AM |
error: missing ilok authorization for pro tools... please insert the necessary ilok. | Witold.B | Pro Tools Express on Mac OS X | 1 | 04-21-2014 03:59 AM |
error: missing ilok authorization for pro tools 9. please insert the necessary ilok.. | weakluv | Windows | 2 | 07-07-2011 05:47 PM |
ilok detected on ilok.com but not with pro-tools software | emergems | Pro Tools M-Powered (Win) | 5 | 12-27-2010 10:36 AM |
