Old 09-20-2017, 01:12 PM
psujohnny03 psujohnny03 is offline
Default Recording Piano but Sustain Pedal not being recorded
Hi, I am trying to record a piano track using my Yamaha WK 225 keyboard in MIDI mode. I can make a recording but for some reason my sustain pedal, which is plugged into the Yamaha keyboard via 1/4 jack, isn't being picked up in the recording at all. Is there a plug-in or something for a sustain pedal? How can I record keys with sustain effect? I am currently using Pro Tools 11 Trial and will be upgrading to PT 12 soon. Many thanks for any help you can provide! Rock On!
Old 09-20-2017, 02:26 PM
Default Re: Recording Piano but Sustain Pedal not being recorded
Also, my keyboard is in MIDI mode but does not have MIDI output, I am plugging keyboard into computer via USB.
Old 09-20-2017, 03:37 PM
john1192 john1192 is offline
Default Re: Sustain Pedal effect not being recorded along with piano part.
system info please ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 09-20-2017, 03:53 PM
Yamaha WK 225 ? You mean Casio WK-225?
MIDI is MIDI, wether over USB or legacy 5 PIN DIN wiring. The wiring won't make a difference here.
Does the sustain pedal work on the keyboard playing locally? If not what brand/model pedal is it?
Have you looked through the user keyboard documentation at MIDI and sustain pedal configuration settings?
What VI are you using? What is showing in the sustain pedal MIDI track? Are the note on/off stretched with sustain being held on?
I am not even sure this keyboard sends sustain out vs. note/start stop. The documentation, a MIDI sniffer/monitor utility will tell you for sure.
Old 09-20-2017, 04:34 PM
Sustain pedal does work fine with the keyboard and I hear the sustain is active while I am playing and recording. However, there is no sustain when track is played back so, it must not have got recorded at all. Yes, sorry, it is Casio not Yamaha. Sustain pedal is a BOSS FS-6.
You asked "What VI are you using?"
Did you mean DI?
System specs:
Dell Desktop
Windows 10
PT11 Trial, upgrading to 12 soon.
Focusrite Scarlett 2i2
Yamaha HS5 monitors
Casio WK 225 Keyboard
Old 09-20-2017, 04:42 PM
No I'm asking what VI are you playing the MIDI thought in Pro Tools.
Old 09-20-2017, 05:54 PM
Oh, sorry, new to this. I tried it with both Xpand and Mini Grand.
Old 09-20-2017, 06:14 PM
reflexson reflexson is offline
Turn off midi merge in the transport.
Paul Cox
www.226recordings.com
Old 09-20-2017, 06:51 PM
Can you explain in more detail how to do that? Many thanks!
Old 09-20-2017, 07:38 PM
MIDI Merge: Google or the Pro Tools Reference Guide (searchable PDF already on your computer) can explain all you need. Please try to spend some time helping yourself here.
I don't follow how MIDI Merge is related to your problem, I just hate to think you are unable to find how to use a Pro Tools feature.
PT11 no sustain pedal data recorded john1192 Pro Tools 9 2 03-30-2014 11:41 AM
MIDI Record Piano no sustain pedal MarkWorsnop Pro Tools 10 1 06-17-2013 08:58 AM
Serious problem! piano sustain pedal controls tap tempo through midi! gvees Eleven Rack 1 07-28-2012 03:54 PM
Problem with recording MIDI piano sustain pedal Chris7514 MIDI 5 06-11-2008 12:56 AM
Piano sustain pedal in recording Help!! Zownd Tips & Tricks 9 04-05-2004 02:21 PM
