Old 04-11-2017, 11:34 AM
R4yptor R4yptor is offline
Default MIDI issue
Hi, i see other people posting here with midi problems, so I'll post mine here too.
When I lay down notes right behind each other, they are all played as a single one, like if I did a singular long one. In one session it worked just fine, but in others not. I assume it could be fixed with editing through an event editor and tweak the start/ends of each note, but doing this over and over again would be really annoying. By the way, when I wanted to do so and opened the editor, all of the notes had the same start/beggining time value.
Any idea what's wrong here?
Old 04-17-2017, 09:31 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: MIDI issue
Need more info. Could you state exactly what you're doing, what your set up is, and how you're recording your MIDI notes?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
MIDI problem - Midi Studio Issue Microphone33 MIDI 4 02-27-2016 11:49 AM
MIDI problem - Midi Studio Issue Microphone33 Virtual Instruments 0 02-07-2016 02:09 PM
midi issue- can see midi signal but cant's control Xpand2 macroniche Pro Tools 10 1 08-02-2012 12:16 AM
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 07:57 AM
Issue When running Midi and more than one Midi Track amayhem MIDI 11 11-05-2009 06:52 PM
