Re: AJA io XT
The good news, the Aja i/o xt will accept audio via embedded sdi no problem.
You can feed it tri level sync or any reference flavour I guess. It sounds fine, as I played a 5.1 mix out of it and then my native rig chased it via ltd. Hooked both up to my xmon and switched back and forth. I could hear no difference, (i use an omni for monitor out) Bad news, it has a fan whine that is crazy. I would need to put it in another room for sure or buy a mega iso box. Calling Aja to see if there is anything I can do about the fan. Aja is replacing the unit! Last edited by puffin; 02-02-2015 at 04:38 PM. Reason: great service |
Re: AJA io XT
Unit replaced, Aja support is crazy amazing and responsive!
Works like a charm! |
Re: AJA io XT
Not related to your problem…but I simply removed the fan from my Aja LHI card. Its now "surprisingly" silent for about a year I have it in my MacPro. The chip is not overheating and getting maybe to 60-70 degrees Celsius which should be ok for most silicon electronic components.
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
Re: AJA io XT
Re: AJA io XT
Well, of course they have put the fan for a reason.
And yes, I am risking a bit...but not allot. First of I work in fully AC controled room. Second, the fan of this size doesn't cool allot anyways. Third the card is in the slot which receives a maximal ventilation from the Mac's main fans. Forth the card doesn't work too hard in terms of no capturing, cross converting or H264 processing. Taking all these facts into account I assume that my risk is minimal. And yes its still my own risk...so don't try it at home as its not "by the book" practice.
#16
Re: AJA io XT
#17
Re: AJA io XT
Hi Michael,
I just had this same problem start with my second hand LHi making a massive noise from the fan. How did you remove it? I undid the little clips that hold the pins with the springs on, but its still firmly attached to the chip. Thanks Martin
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
#18
Re: AJA io XT
BTW: it works like a charm without a fan for quite a long time if someone is wondering.
#19
Re: AJA io XT
Ah Ha! Glue, who knew?
Thanks Michael. When you say it lasts quite a long time does that mean yours has died now? As the card only cost me $85.00 I'll be happy even if it doesn't last too long.
#20
Re: AJA io XT
Wow for $85 it should be called a bargain or a no brainer in "plugin hunters lexicon"
