#21
Re: vocal booth causing vocals to sound very boxy
Me too. It is one of the reasons I still tolerate Waves. Another reason is Dorrough meters, and the number three being L3LL-Multi. Without those three, I wouldn't have a reason to use their products.
#22
These are all good and correct ideas. Along the line of better wall quality treatments.
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
#23
"boxy" usually means "walls" are too close to the source...
#24
Or wrongly built with cheap material that kills the tone too much.
Best Regards Christopher #thestruggleisreal ————————————— South Side Music Group WEBHOME ————————————— |
#25
This could be your friend: https://www.seelectronics.com/rf-space/ I've had far too many post-session cocktails to work out what your standing waves are but I wouldn't be surprised if you simply don't have enough space to put enough trapping in to get rid of any problems. Sorry I can't be more positive but these booths are designed to cut out spill, not sound good.
Dave Marsden UK |
#26
so your saying it'll be a waste of time to get the 4 inch foam?
#27
Foam doesn't do what you are after. It's OK for taming some high frequency flutter, but your problem would have to be attacked with a different material; Rockwool, Roxul, etc. Foam is pretty much decorative.
bookerv12 |
#28
yes, use rockwool!
Gesendet von iPhone mit Tapatalk |
#29
or even better as Rockwool is Basotect , with very interesting
capabilities , as seen here : https://hofa-akustik.de/en/modules/measurements/ simple "foam" doesnt reduce the most problematic low-mid and low frequencies in small rooms
foley artist , soundeditor |
#30
basotect for fullrange absorbing needs to be pretty thick and that's expensive! mineral wool is very effective when you use the right density (look for 60kg/m3 = 0.5lb/gal (US)) but needs to be covered with fabric.
Gesendet von iPhone mit Tapatalk Last edited by edwinstar; 04-22-2017 at 11:05 AM. |
Vocal Booth | Mr.BossPlaya | Tips & Tricks | 4 | 07-04-2006 08:33 AM |
How to build a sound proof vocal booth? | CrAkD | General Discussion | 3 | 06-01-2005 12:59 PM |
vocal booth sound evaluation--help? | tokyofan | General Discussion | 3 | 02-24-2005 11:33 PM |
boxy sound | stickstome2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-28-2004 10:07 PM |
Why do my mixes sound "boxy"? | Kickin.da.speaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 68 | 05-31-2001 11:19 PM |
