xp32 bit 1394 Light Blinks goes away freeze at DAE
important note: when i use my old mac (the one im replacing with this new pc build) pro-tools opens fine, so this is no problem with the DIGI 002 rack, not a power harness issue.
SiSoftware Sandra Computer Model : Gigabyte EP43T-UD3L Workgroup : OFFICE Host Name : sound User : Bethany Processor Model : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Speed : 3GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Mainboard : Gigabyte EP43T-UD3L BIOS : Award (Phoenix) F3 10/16/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.5GB DIMM DDR3 Chipset Model : Giga-Byte P45/P43/G45/G43 DRAM Controller Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 8GB DIMM DDR3 Memory Bus Speed : 2x 666MHz (1.33GHz) Memory Module(s) Memory Module : Corsair CMD8GX3M4A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD8GX3M4A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD8GX3M4A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD8GX3M4A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce 9500 GT (32 SP 1.35GHz, 1GB DDR2 2x400MHz, PCIe 2.00 x16) Graphics Processor Adapter : NVIDIA GeForce 9500 GT (32SP 4C 1.35GHz, 1023.7MB 2x400MHz) Adapter : NVIDIA GeForce 9500 GT (32SP 4C 1.35GHz, 1023.7MB 2x400MHz) Storage Devices WDC WD6400AAKS-00A7B2 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 596GB (C:) (E:) (F:) WDC WD6400AAKS-00A7B2 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 596GB (D:) (G:) Optiarc DVD RW AD-7240S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 589MB (H:) Optiarc DVD RW AD-7240S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 2GB (I:) HL-DT-STCD-RW GCE-8525B (USB) : N/A (J:) Logical Storage Devices Hard Disk (C:) : 100MB (NTFS) @ WDC WD6400AAKS-00A7B2 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Windows 7 (E:) : 298GB (NTFS) @ WDC WD6400AAKS-00A7B2 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Windows 7 Drive2 (F:) : 298GB (NTFS) @ WDC WD6400AAKS-00A7B2 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Hard Disk (D:) : 298GB (NTFS) @ WDC WD6400AAKS-00A7B2 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Backup (G:) : 298GB (NTFS) @ WDC WD6400AAKS-00A7B2 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) GRTMPVOL_EN (H:) : 589MB (CDFS) @ Optiarc DVD RW AD-7240S (SATA150, DVD+-RW, CD-RW, 2MB Cache) GIGABYTE (I:) : 2GB (CDFS) @ Optiarc DVD RW AD-7240S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (J:) : N/A @ HL-DT-STCD-RW GCE-8525B (USB) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : Giga-Byte HD Audio Controller Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB368 IDE Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Disc Publisher II (600x600, USB, Colour) Network Services Network Adapter : Realtek PCIe GBE Family Controller - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 approved firewire card bought from digi website SIIG DP firewire 2-port PCIe Listed As "FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link)" Under Peripherals PROBLEM: Open Pro-Tools, gets to "Creating DAE Objects" Freezes, mouse does not move, nothing responds, ctrl alt delete no response, have to force reset computer Ive reinstalled OS 8 times , always uninstalled IE 8 Tried running pro-tools first, then installing quicktime, i heard on forums it might help, did not work attempted with just 2 gig of ram in, no effect everytime i run pro-tools it gets to creating DAE objects the light stays on for 1 second on 1394 on digi002 then goes blank, then freeze computer have to force reset. bought approved firewire card from their website of approved cards, same problem. im desperate to figure this out ive tried everything i can think of. spent 2 weeks at work trying different things, nothing works. NOTE: In device manager i can clearly see the digidesign digi 002rack listed, under IEEE 1394 i can see the TEXAS instrumentals OHCI compliant IEEE 1394 Controller when i turn off rack it goes away when i turn it back on it reappears in device manager so it can see it.... i have pro-tools 8.0 installed on xp 32 bit. ive tried the beta drivers on windows 7 under 8.03 to 8.04 same problem happens there as well freeze at DAE objects light stays lit on 1394 for 1 sec then goes blank tried disconnecting printer and internet / network.. also no effect HELP!! Last edited by SamuelAdams; 04-11-2010 at 08:27 AM. Reason: Sandra Report |
Re: xp32 bit 1394 Light Blinks goes away freeze at DAE
Help us help you - what you need to know before posting!
post a Sandra report
Bump - I did what you asked, any help please? let me know with whatever info i can additionally supply you with. thanks so much
Sam Adams,
Have you tried turning off your 002 when PT errors? Turning it off should throw PT to an error to close gracefully. Sometimes my PT doesn't load and a power cycle of the 002 will get it going. I call it Digi voodoo (?). When you power cycle the hardware (002), always wait about 30 secs between turning off and turning on. Chips need time to 'power down'. And when restarting software (PT) same thing. Let the PC memory get freed before you restart your software (PT). Resource Monitor is good here if you interested (get the four counters to 0% and youre gold). Seems your network might be running, dunno about Macs but PT on PC's does not like network services running. Mike. P.S. jameelb there's a NEW THREAD button at the top of the forum screen where you can see the threads listed.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
i have tried this , this does not help.
sometimes it doesn't get to creating DAE objects and it just tells me my unit is not on please turn it on and click ok, tried power cycle down waiting 30 sec on 30 sec still does not see unit even tho its in device manager showing it clearly as there and i have a approved firewire card, no effect disconnecting network / internet cord, same thing. tried disconnecting printer also no effect |
Try pulling 4 GB of memory out. Deleting your Prefs and rebooting.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Tried pulling out 4 gig of RAM, no effect, any other ideas? thx guys!
PS - your specs say you have 12 gig of ram? and im guessing yours still works ya? |
Kinda my bad...PT would hang on a 64bit system with 4 GB and a FW interface.
any more help anyone? im sooooo stuck
I don't see the SIIG card listed in your Sandra report - is there a reason for that?
I'm thinking that this may be a FireWire driver issue. I would try reinstalling the drivers for your FireWire devices in the Device Manager. You may also want to try disabling DEP, as that could cause an issue like this. How to disable DEP |
003 rack is not connecting. Blinking green light. no HOST 1394 light. | ccgascity1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-14-2011 12:41 PM |
1394 Light Blinks In Win7/64, But Not XP? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-27-2010 02:49 AM |
1394 Light not WORKING!!! light not coming on at all HELLLPP | Shizzle408 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-24-2009 03:42 PM |
1394 led light blinks on 002 | Irenaus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-18-2008 08:08 AM |
1394 light on my Digi 002 Rack blinks and locks up | mseans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-12-2006 03:20 PM |
