#31
Re: Completely Frustrated!
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
#32
The port on the computer doesn't seem to be a snug fit. I tried a little experiment last night and was just listening to some music, but running it out through the 002R. It worked good for quite a while then suddenly stopped playing music and emitted a high pitch frequency out of the speakers. I turned off the 002 and reconnected and was fine again. Maybe it's the cheap cable i'm using? I've looked at more expensive cables but i'm torn on using one if it isn't going to solve the issue.
#33
Now I always turned off BOTH the 002 AND the computer before unplugging the firewire cables. I did this because I read about possible damage from hot swapping firewire devices. If the computer is still on, there is a voltage going through that port and unplugging a cable could be a problem. It might be an unlikely problem but if there is a possibility, I would avoid doing that.
If you've tried multiple FW800 cables and they are all loose (no snug) at the computer's FW port, then It would point to a physically damaged FW port on the computer. Although you have used a piece of tape to make it fit snuggly, it may not make a good electrical connection. Unfortunately, on MacBook Pros, I think the FW ports are soldered onto the logic board, which makes replacement near impossible for anyone other than the most skilled technicians. Apple may replace the whole logic board but that will cost more than the value of the computer.
Obsidian Dragon
#34
OK, i think i've finally figured it out. I had a bad power supply that seemed to be interfering with the firewire port. I ran the computer on battery supply and everything worked fine. As soon as battery was running low and i plugged in the power supply i immediately lost firewire connection. So, i used another power supply and i clamped on a ferrite bead to the firewire cable and all seems well for now! I was able to run the system for a few hours without a hitch. Hopefully this keeps working for a while.
Completely Frustrated | michaelhulse | Artist Series | 2 | 03-08-2016 12:52 AM |
Very Frustrated | musicalnyc | Licensing & Accounts | 2 | 03-03-2016 07:09 AM |
Frustrated!!! | amateurtool | Pro Tools TDM Systems (Mac) | 13 | 04-22-2011 06:19 PM |
Frustrated in BFD | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 09-28-2006 11:27 AM |
So frustrated please help me | universe777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-28-2006 10:23 AM |
