Old 01-03-2009, 04:48 PM
bentley bentley is offline
Default no reason engine
uploaded the free reason for digi 3.0 from the propellor site as was reccomended .
All looks fine except when I try launching, I get a "can't find or install reason engine".
I got the auth and serial codes correct and the reason icon starts bouncing and everything...
Where is the engine?
macpro 2.8 10.5.5 2 gig ram, ptle8, 003r+
Old 01-05-2009, 12:36 AM
pre911mindset pre911mindset is offline
Default Re: no reason engine
Hi, I had the same issue and it turned out to be a file permissions issue. Check out this link:
http://www.kenmc.com/2008/02/02/fail...ngine-exiting/
Basically you need to make sure you have right permissions in in library/Applications Support/Propellerhead... where your reason engine lives.
I am new to the mac and don't quite get this concept of files going onto your machine but you don't have perms. to use them, I get burned by it quite often.
Old 01-05-2009, 05:54 AM
Will Russell's Avatar
Will Russell Will Russell is offline
The fix for this is in the documentation that came with PT8. Top of page 3 in the readme.
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.14.5, PT2019.6, HDX, D-Command
Retina 5k iMac OS 10.14.5, PT2019.6, MBox3
Retina MacBook Pro OS 10.14.5, PT2019.6
Old 01-05-2009, 12:34 PM
That did it.
You guys are awesome!
Can not open Reason Engine (PT 8.0 w Reason 4.0) pietro79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-13-2009 03:13 PM
Reason Adapted Engine Problems!!!!!!! mr.mslife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-20-2008 06:00 PM
reason engine plug in dmartin714 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-25-2008 05:40 PM
Reason Engine eldusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-27-2005 03:50 PM
Reason Engine Failure? trahern 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-29-2003 12:39 PM
