Old 12-10-2017, 03:59 PM
guhlmann guhlmann is offline
Default Import Audio Function Broken
Could anyone advise on how to fix the import audio function in Pro Tools. It was working fine, but now in every session I open up this message appears:
Could not complete the Import Audio command because Assertion in "/Volumes/Development/158347/ProTools/NewFileLibs/Cfd/MacOS/Cfd_ImportAudioDialogMacOS.mm", line 603.
Thanks,
Greg
Old 12-10-2017, 04:07 PM
strangepumpkin strangepumpkin is offline
Default Re: Import Audio Function Broken
Which version of Pro Tools? Mac? Which OS for Mac?
Was something installed prior to the import audio function not working?
Kyle Whittaker
www.strangepumpkin.ca
Mac Pro (2013)
3.5GHz 6-Core Intel Xeon E5
32 GB Memory
OS X 10.12.6
PT 2018.1
Old 12-10-2017, 04:11 PM
Pro Tools 12.4
MacBook Pro (2014)
macOS High Sierra Version 10.13.1
Old 12-10-2017, 04:12 PM
I'm wondering if I may have installed the OS update (High Sierra) between the time of the function working and it breaking. I can't say for sure, but that is very possible.
Old 12-10-2017, 04:13 PM
Originally Posted by guhlmann View Post
Pro Tools 12.4
MacBook Pro (2014)
Well, first off, Pro Tools 12.4 is not officially supported by Avid for macOS 10.13.1. Only PT 12.8.2 is.
So that could be your problem.
Kyle Whittaker
Mac Pro (2013)
32 GB Memory
OS X 10.12.6
PT 2018.1
Old 12-10-2017, 04:33 PM
john1192 john1192 is offline
if everything else with PT is working than you can drag and drop audio into the tracks menu or the Edit window .. there was a version of PT that had an issue with import audio on some systems ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Audio Import - Interleaved / Dual Mono Broken john1192 Pro Tools 12 8 05-06-2016 03:20 PM
Compact function is broken! digidesigner Pro Tools 10 8 04-03-2012 12:57 AM
Import Audio function doesn't work in 8.03 resway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 21 04-02-2010 09:03 PM
Search function in "import audio" window useless mr.armadillo Pro Tools TDM Systems (Mac) 9 01-31-2007 09:37 AM
7.1cs7 Consolidate audio (on import) still broken Farmer Dave Pro Tools TDM Systems (Mac) 4 05-22-2006 02:02 AM
