Old 10-03-2002, 06:30 PM
flymax flymax is offline
Default Double notes being recorded from controller keyboard?
I had this same problem awhile ago but the fix I used then won't work now. Here's the system= Mix+, MTP AV, Controller keyboard- When I record midi from the controller keyboard I'm getting two notes- one that's really short and one that reflects the actual sustain. When I had this happening a few months ago someone pointed out to uncheck the MTP from the input devices and leave the keyboard checked. I did this and the problem was gone. We rebuilt the system recently and I think I got it all set up right.
I ran free midi and have it set to default to OMS. I ran Clockworks and have the routing going where I want it. OMS appears to be set up properly.
Thanks in advance for an help. I'm really stumped on this one.
-Pete
Old 10-06-2002, 04:59 PM
Default Re: Double notes being recorded from controller keyboard?
I fixed it. It was the controller- it was set to send double notes.
Midi notes double Shatzer Pro Tools M-Powered (Win) 7 03-20-2015 04:30 PM
Recorded Double Tempo? Skanz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-21-2011 04:02 AM
double notes john1192 MIDI 0 04-17-2007 08:03 AM
Double Notes!!!! roziel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-02-2007 09:30 PM
MIDI double notes on everything writethis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-27-2002 10:37 AM
