MacBook Pro quad core touch bar
anyone finding the Touch Bar of real use with Ultimate?
!#$@@$#! "Do not fear mistakes. There are none." Miles Davis |
Re: MacBook Pro quad core touch bar
With better touch tool (think it is around 7 USD) you can map your favorite key commands and much more to user designable touch buttons in any app....I like it.
(I originally bought BTT because I kept on hitting the esc touch key, with BTT you can remove or move it....) But i guess it is all personal... Dan Sent from my iPad using Tapatalk |
I've been using BTT and/or Karabiner for a while. But I was more thinking is it worth anything for the "hardware" keys.
I only have PT 2018.12 but didn't think Avid was supporting the Touch Bar currently. Some apps apparently are starting to allow you to create custom shortcuts you can add the the touch bar. so I'm guessing this will be more of open access for developers like Avid to access or not. unless in the ultimate versions avid has given you access as a feature? not available too us mere mortals
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
mortals. heh, heh, heh
Dual Core vs Quad Core new Macbook Pro | ramonetl | General Discussion | 20 | 11-04-2016 05:05 PM |
Macbook Air 2014 (1.4ghz Dual-core Intel core i5 Vs. Mid 2010 MBP i7 Quad-Core and PT | TheGoodhusbands | Virtual Instruments | 2 | 09-11-2015 10:49 AM |
MACBOOK PRO 15 Quad Core I7 2.2g | 12bbb | Pro Tools 11 | 13 | 01-03-2014 06:16 PM |
Which new Quad Core, MacBook Pro should I get? | drumster | macOS | 15 | 09-11-2011 08:06 PM |
macbook pro vs mac pro quad core | bassgenius | macOS | 4 | 01-23-2011 11:05 PM |
