PT 11.2.1 occassional playback engine error
Every so often when I open an existing session in Pro Tools, I get a playback engine error saying to increase the h/w buffers (they're at 256k: HD Native) when I playback audio the first time. If I ignore the error and try to play the tracks again (audio, not midi), there is no error from that point on.
Has anyone seen this issue? It seems minor since it only happens every couple weeks or so. I'm going to keep an eye on it to get a better handle on the details when it happens. |
Re: PT 11.2.1 occassional playback engine error
What is the error code?
Thanks for the quick reply. I've reproduced the error.
Here's the specific error message: “Audio processing could not complete due to convicts with other CPU tasks or a potential clocking issue. If this occurs often, verify your sync cables or try changing the HW Buffer Size setting in the Playback Engine dialog. In most cases, a larger buffer size will prevent the problem. (AAE-9172)” I do have Firefox and a text editor running at the same time to work through material for a Pro Tools course I'm taking, so I wonder if that's the conflict (?). |
What happens if you increase the buffer size to 512 samples before playback? It sounds like an initialization issue if it only happens on first playback.
I'm getting an error similar to this, AAE-9173 on the PT demo session. Plays fine the first time with low CPU usage but refuses to play a second time. Seems the OP has an error the first time but plays the second time without error.
Pro Tools ran out of CPU power. Try de-activating or removing Native plug-ins. -9173 And when it stops, I get dancing CPU meters with the main meter turning RED.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
In either case, does turning on ignore errors (Setup-->Playback Engine) make any difference?
Not for me. And increasing buffer size doesn't help either.
Hi Folks,
Me too on the 9173 error. Constantly... but I'm on a i7 16gb Windows PC, Pro Tools v11.3.. Certainly can't upgrade to 12 with expectation of same issue and with work piling up this is the first time in my career I'm thinking of other DAWs to check out. I've removed all plugins, left in stock plugins, deleted database/preference, reinstalled Pro Tools, Mbox 3 drivers, et al. What do we all have going on that might track this down? VI's? I use a bunch. Kontakt Komplete 10, Waves Gold bundle... removed 'em and reloaded because of same issue. Or is this just a PT error and nothin' we can do about it until fixed? Windows 7 i7 16gb |
Do any of you have a support/upgrade plan that you could open a case with Avid about this? Their .dlog files might have the answer, though they are encrypted and can only be read by Avid.
My support unfortunately expired before the issue occurred.
Playback engine error! | ktwalker76 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-27-2011 11:25 PM |
error playback engine PLEASE HELP | batchmister1 | Pro Tools M-Powered (Win) | 0 | 07-02-2007 08:25 PM |
playback engine -6088 error PLEASE HELP :( | thexflamesxburn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-20-2007 09:12 PM |
Playback Engine Error Messages | egrantley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-30-2005 08:25 PM |
Playback Engine Memory Error in PT6.1 | Armando Romeu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-17-2003 04:00 PM |
