01V96 V2 Sync Problem
Hey all,
Tried searching but couldn't find the answer to this one... I just got a 01V96 V2 and am coonecting it to my 001 using lightpipe. I'm getting a "Sync Error! (ADA IN)" on the 01V. Can anyone help me out as to how I should have this set up. I've been going through the manual(s) and trying different things and am stumped. Thanks so much!! |
Re: 01V96 V2 Sync Problem
Hi Frank,
You have to make sure you turn 001 into slave mode and the 01v96 to send master clock via the ADAT ports. or the other way around if you want 001 to be the clock master (which I don´t reccomend) Good luck.
"Ok I promise, this is the last plugin I´ll buy!" www.syrland.is www.sturluson-music.com |
You may need to set the O1V/96 to operate at 48K.
Yamaha 01v96 v2 sync... all ports... | TacosFame | Pro Tools M-Powered (Win) | 0 | 10-16-2010 06:50 AM |
YAMAHA 01V96 world clock sync problems | David Khositashvili | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-26-2009 09:36 AM |
01V96 sync issues with Protools 7.4cs5 | FLi | Pro Tools TDM Systems (Win) | 2 | 09-10-2008 10:31 PM |
Sync Mbox-002r-01v96-Rosetta-MIDIoverLan | dubaifox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-11-2005 12:15 AM |
01v96 control problem | Bonez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-17-2003 07:41 AM |
