Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 04-15-2019, 10:48 PM
Randydrums29 Randydrums29 is offline
Default HELP. Can't get hardware to work for mixing. Presonus 192 and PT2018
I have PT2018 with a presonus 192 and a DP88. I'm trying to get my hardware to work as a insert for mixing. I have my inputs and outputs hooked up correctly on hardware and interface. Tried in and out of channel 3 on 192. I've also tried in and out of channel 8 on dp88. My issue has to be something in my I/o setup. I've tried bypassing mixer in presonus's UC. I've also tried it with UC mixer active. As soon as I add an insert on the channel I don't get any audio. Any input or guidance will be very much appreciated. Right now I have my inputs, outputs, busses, and inserts set to default.
Old 04-19-2019, 09:58 AM
jwilkers jwilkers is offline
Default Re: HELP. Can't get hardware to work for mixing. Presonus 192 and PT2018
I have the exact same setup on a MacBook Pro. What are you using? It's a little tricky but when you get it figured out it works great.
Do not bypass the mixer.
Make note that the Mains are actually Outputs 1-2 in Pro Tools and 1 and 2 are really 3-4 etc.
That's a bit confusing.
Are you hooked up USB to 192 and Optic to DP88?
Let's go from there.
Mine has been hooked up for so long that I may have to take a look.
Old 04-19-2019, 02:25 PM
skizzo skizzo is offline
it is doable. I do not bypass the universal control software mixer. i have my stuff routed so in UC I have channels 3-8 as potential insert I/Os or whatever. In UC "mix 3/4" is going to be outs 3/4 in PT. mix 5/6 in UC will be out 5/6 in PT. and so on. so it sounds like you just need to get a little more familiar with the routing controls of UC
Mac Pro '09 - 5,1 - Dual Hex Core X5680 3.33 ghz CPU - 48GB RAM
970EVO 500GB (10.13.6) - 1TB WD Black HDD (Samples) - 6TB Toshiba HDD (Backups) - 500GB Glyph GT050Q (Legacy sessions & backups) - 3TB Glyph Studio (Main audio/sessions)
HD5770 GPU
OSX 10.13.6 - Pro Tools 2018.12 - Presonus Studio 192 / Digi 003 Rack+
Focusrite Clarett OctoPre - AKG HPE6 - DBX160A - WA76
Old 05-11-2019, 05:59 PM
I just saw someone had responded to this. Hopefully you can still help. I got studio 192 hooked up by usb3 and dp88 by optical.
Old 05-11-2019, 06:46 PM
And those folks replying are giving details and providing advice, ... and it's not clear at all what you are doing. Saying you have stuff "hooked up correctly" tells nobody here anything useful. Folks here are likely to give you vey specific advice if you provide really clear descriptions of what you are doing.
Trying to get "my hardware"... what exact hardware?
Connected to *exactly* what ports at the same time... did you see the comment above about the actual port pairing? << because of that previous comment, I suspect you have the wrong port pairings.
Optical to where? How? You mean you have the dp88 hanging off the 192 via ADAT?
What are you doing with universal control? (see comment from previous poster)
What testing have you done? The first thing to try to do is get a piece of wire/coax working as an insert. Have you done that? If it does not work... start fishing around and confirming what outputs and inputs are hot (got a multimeter?)
Why does the DP88 matter? Why mention it? Simply things if needed, disconnect the ADAT box and get the insert running between two correctly matched ports on the 192.
Duplicating a track in PT2018.7 doesn't work. Why? senghor Pro Tools 2018 5 10-24-2018 12:34 PM
feedback on PreSonus StudioLive 24.4.2 and Series 3 SL24 and PT2018.7 xrekcor Third Party Interfaces 3 08-22-2018 03:58 PM
External Hardware with PT2018 and Uad Apollo [solved] spock999 Pro Tools 2018 1 03-08-2018 02:37 PM
tracking / mixing via PreSonus StudioLive 16.4.2 bacchus40 Pro Tools 10 0 06-08-2012 12:18 PM
Bumping the PT9 and Presonus hardware issues The Bagwhan Windows 0 03-02-2011 12:59 AM
